Mahindra Max 28XL or Kubota B2920?
   / Mahindra Max 28XL or Kubota B2920? #61
Nice Vid.....BUT.....It may just be an optical illusion, but I could swear that if you pause theat video @ 1:56 and again @ 2:11 it looks like that lift cylinder is bowing:confused2:
In all of this rambling though, I totally forgot about curl force. I have been talking (and I guess we may not have been on the same page) about LIFT ONLY. When I lifted my propane tank (~1400-1500lbs), it was LIFT only. Curl was NOT used. And I was rigged @ the cutting edge. So Yes, that max probabally would have lifted it but ONLY with curl.
This has now got me wondering how much I would actually be able to lift if using curl function as well. Because I never do that when lifting something to move because that adds WAY more stress on the lift circuit. In that vid, if you went into relief @ 900lbs lift, and you almost doubled that with the curl, that means them cylinders and hoses are seeing almost double relief pressure as well :EEK:
We were actually on the same page, the curl idea just came along at the last minute and frankly we were surprised when the back of the forklft came up.
And you are right, whenever you are at max breakout force, you are putting everything near maximum. It really isn't smart to be using the curl to maximize lift on a regular basis. If you needed to do this, you should buy a larger tractor. This was just a demo for someone that thought a Max would have the rear in the air without a tremendous amount of ballast.
There is no doubt that your much larger Kubota L series will outlift any SCUT, as well it should. But, I'll take your Kubota in trade if you insist....:D. Would that be the sale of the year or what? :thumbsup:
   / Mahindra Max 28XL or Kubota B2920? #62
Wild!!! I need to get one of those scales... I'd like to test my Max28XL.
Dave, where can I buy a scale/gauge (what is the proper terminology?) to perform the same test? I cannot find a tool like that, with that capacity.
   / Mahindra Max 28XL or Kubota B2920? #63
I am suprised it only had 1700lbs over the back when unloaded:confused2:
Probabally the lower lift height and keeping the bucket in tight. You said 46" from axle CL to edge right??? I measured mine. It is 66". So I guess that is a good bit there.
I still dont consider the Max a SCUT:laughing:, And if you insist on a trade....I'll take a 4035 HST 4wd w/FEL and 3 remotes even up on the trade:D
And in all seriousness, your vid prompted me to do some tests of my own in my own crude way. Results and pics to come. Give me 15 minutes to type it up and upload the pics:thumbsup:
   / Mahindra Max 28XL or Kubota B2920? #64
Okay....Here goes.
My crude setup I will describe but the pics will show it best. All I have is 2 550lb game scales. Which I believe show about 10% LESS than actual based on weighing myself on certified scales at work and then on these. But I wont use that for any excuses.
The setup is with a big pully. Since only the 2 scales give me 1100lb capacity, with a simple pully, I can double that. So basically with the setup and 2 scales, lift force is actually 4x's what is shown. All this is hooked to the outrigger on the 5500BH.
The first pic is the set-up. and then LIFT ONLY. Scale shows 330# which is actuall 1330#. (This is at the cutting edge as you can see). Not bad.
Now for curl test:confused2: I kept the lift pressure on. Gauge shows ~2700PSI and it is only a 3000PSI guage. I hit curl and the gauge pegs instantly proving that there is WAY more than relief force when using a "curl assisted lift". Anyway....Keep going. Back wheel lifts. I improvise quick and chuck a 50# rock and an hunk of wood on the back of my ~1100# cutter. Keep going....... Big game scales are 550#. Well around goes the dial and back to ~35 or so past 0:confused2: There is about a 20# void between 550 and 0, so going back to +35, we are now at about 605#. Up comes a back tire again:confused2: In all fairness, I was on an ever-so-slight grade. but at this point, I call it quits. No point in seeing what the inside of the scales look like scatterd all over:laughing: so...605 x 4 = 2420# curl force and probabally a tad more with a good way to measure.
Next thread.....How to Fix Ford 5500 outrigger:laughing::laughing:
PS: Backhoe stayed down. Note to Dave....Use sufficient weight when testing FEL
   / Mahindra Max 28XL or Kubota B2920? #65
Cool test, LD1.
I found some sites with those mechanical crane scales / dynamometers... they are expensive. Maybe I can borrow one somewhere...
So... these words sound like someone who's put some thought into owning a Mahindra:
"I still dont consider the Max a SCUT, And if you insist on a trade....I'll take a 4035 HST 4wd w/FEL and 3 remotes even up on the trade"
Just sayin... :)
   / Mahindra Max 28XL or Kubota B2920? #66
Cool test, LD1.
Just sayin... :)
I consider everything when buying. And I always like to window shop:licking:
If I had the money, I would own one of everything. But If I ever get another tractor (not ant time soon) it would be a tough decision between a mahindra 4035/5035, kioti DK40/45/50, and a kubota M or L5040.
But there will probabally be several new models come and go before I ever get another. I just figured if he wanted my Kubota bad enough (to have a REAL tractor on the lot:laughing:) It was worth a shot.
   / Mahindra Max 28XL or Kubota B2920? #67
Smart man LD1. Plan ahead :)
Thanks for doing that test and pics. Daves video is wicked cool.
I don't really want to spend $800 for one of those crane scales... but I would like to have one... maybe your method is something to consider.
I've enjoyed our discussion. I'm learning. I always will be.
Be ready for alot of newbie questions over the years...
Orange Man (premature board name?) - is the Max 28XL HST or shuttle shift? I see Mahindra lists both on their web site, but when I downloaded the PDF spec sheet, it only showed the shuttle transmission. In that size tractor, and for what you want to do, I would not want anything but HST. HST vs shuttle would account for some of the price difference, if in fact the Max 28XL you're looking at is shuttle and not HST.
Yeah, it could very well be a premature board name, hahahaha! The Max 28XL is HST. Yes, don't think the shuttle is my kinda thing.
   / Mahindra Max 28XL or Kubota B2920? #69
... it is rare to need more than about 1000 lbs lift capacity on a front loader with a 5' or smaller bucket. So if someone just loves the Kubota or JD and is concerned about giving up 40% lift capacity on the front end loader if they don't buy a Mahindra, I'll concede that for most people it isn't quite as important as the specs show. A load of loose dirt in a 5' bucket is how much? 500-600lbs? Now breaking it out of a pile takes more grunt, and that is where the huge lift capacity is handy. Also using forks to carry stuff makes even a big tractor look small quickly, so if moving pallets around is an important task, get the higher lift. But if you move a lot of palletized stuff, get a forklift. A tiny forklift will lift what a 75 HP tractor will lift.
Dave, there are a few companies in the world that make the real forklift mechanism for the 3pt hitch. I would think that would turn any tractor into a forklift... a real one. Have you come across any of those? I'll try to find the links...
[ame]http://www.youtube.com/watch?v=Wi6Fr_t_Kc8[/ame]
[ame]http://www.youtube.com/watch?v=G-PQby1keyA[/ame]
Orange Man,
Now that many have showed the merits of a red tractor, would you consider another? I really like this one too! TYM 293
Well, I'm going to take a look at a Mahindra Max28XL TLB this weekend at my local dealer which is about 12 miles away. :)
2002 DITCH WITCH FX30 VACUUM EXCAVATOR TRAILER (A51406)
2002 DITCH WITCH...
2011 Isuzu (A55788)
2011 Isuzu (A55788)
2018 JOHN DEERE 410L BACKHOE (A52705)
2018 JOHN DEERE...
2016 MORBARK BOXER 525DX STAND ON SKID STEER (A51406)
2016 MORBARK BOXER...
2012 CHEVROLET SILVERADO SINGLE CAB TRUCK (A51406)
2012 CHEVROLET...
2022 CATERPILLAR 306CR EXCAVATOR (A51406)
2022 CATERPILLAR...
