check those screens
   / check those screens #1
megaboz
Fairmont, WV
'17 2032r (soon)
I just changed my hydro fluid in my 2520, 70 hours. Scary find. I spent hours getting the metal shards, chunks and splinters out of the filter and my hands. Wear gloves when you do it! Live and learn I suppose.
   / check those screens #2
I removed the magnets, and washed mine with Diesel fuel at 50 hours. Mine did not have a much as your appears to have, but washed up quickly.
   / check those screens #4
Thanks for the info, I hope my new 2520 is in by the end of the week. This wait is killing me.
Yours look clean compared to mine. My magnets were covered in shavings. As a matter of fact I had no ideas there was 4 magnets in the screen.
I had been having issues with my hydraulics, and it was due. Surely being 20 hours past first change didn't make it look that way. I know 4 hours of it was at idle.
   / check those screens #6
That is a lot of metal and the color is darker than it should be. Hope your warranty is good because something bad is going on there.:(
   / check those screens #7
What is the standard transmission oil change interval for the JD2520? My 4520 does not require it for 400 hours.
   / check those screens #8
According to my operator's manual:
After the firrst 50 hours
Change engne oil and filter.
Change transmission oil and filter.
Clean transmission suction screen.
After that it's every 200 hours.
I may have been 20 hours late but that is no excuse for the shrapnel I found.
200 hours is too long in my opinion for such a small amount of fluid.
Either way in 10 hours I will be flushing it out again.
   / check those screens #10
im with you on the 10 hour deal man that filter look bad glad you found that before it caused major problems.
UNVERFERTH 330 8 AND 1/2 INCH EXTENSION STUB TUBE WELDMENT FOR FRAME (A55301)
UNVERFERTH 330 8...
2005 CATERPILLAR 730 OFF ROAD WATER TRUCK (A51406)
2005 CATERPILLAR...
2008 Dodge Avenger Sedan (A53424)
2008 Dodge Avenger...
2023 WESSEX RMX500 LOT NUMBER 44 (A53084)
2023 WESSEX RMX500...
2004 Sterling Acterra Cab and Chassis S/A Truck (A51692)
2004 Sterling...
