rswyan
Super Star Member
- Joined
 - May 12, 2004
- Messages
 - 13,163
- Location
 - Northeast Ohio
- Tractor
 - Kubota B2910, Cub Cadet Pro Z 154S, Simplicity 18 CFC, Cub Cadet 782
You'll have a ball with it .... here's a couple of tips (the first ones having to do with tippiness)thanks for the replies, At this point im leaning towards renting the miniEx due to the fact i enjoy trying and doing things even if i havent ever done it before.
These machines can feel a little tippy at times, on an incline - but they (at least the Kubotas I've used) are designed to be extremely well-balanced - provided you know how to take advantage of it.
Think of the boom, dipperstick, and bucket as a large, long lever or counter-weight - it can be both an asset and a liability:
1. If you are going up or down a hill, keep the boom, dipperstick, and bucket on the uphill side as a counter-weight - extend as needed to provide stability and balance. The greater the extension, the more leverage there will be. Always operate in "slow" travel speed on hills.
2. Hopefully the machine you rent will have a dozer blade - typically you want to place the dozer blade on the side that you are digging on - you want to set it firmly in ground and take the weight off the tracks on that side.
3. On an incline, don't dig on the downhill side without having the blade set as described above and the machine leveled. Generally, I try to avoid digging downhill if at all possible. If you are digging on the uphill side, you'll be ok (with the blade set on the downhill side, and the machine leveled) .... as long as you don't go nuts when encountering large immovable objects ....
4. Use caution when on an incline and rotating to dump the spoil .... a fully loaded bucket is more of a counter-weight than an empty one
5. Always wear the seat belt when operating.
