Convert single acting tractor hydraulics to double acting
   / Convert single acting tractor hydraulics to double acting #1
kplew
East Wallingford
Intentional B414
Folks- I have a 63 International B414 with a single remote hydraulic connector. I would like to pull a haybine with a double acting cylinder. Is there any type of valve or setup that would let me do this?
Thanks for your help
Kevin
   / Convert single acting tractor hydraulics to double acting #3
Kplew,
Converting the cylinder would probably be easier. I suspect you would have to replace the complete valve body and i also suspect this would be difficult.
   / Convert single acting tractor hydraulics to double acting #4
Kevin
The answer is, yes you can, but is it worth it in terms of money.
You can add a DA valve and DA cyl and do what you want.
Surplus Center - 1 SPOOL 8 GPM PRINCE MB11B5C1 DA VALVE
Look in the cyl section for the bore size, rod size, and the stroke.
http://www.surpluscenter.com/sort.asp?keyword=HCD2&catname=hydraulic&PAGELEN=20&PageNo=3
You could add a two spool valve for other functions you might need in the future.
Unused Delta Crash...
SAKAI SV544 SMOOTH DRUM ROLLER (A52706)
SAKAI SV544 SMOOTH...
1982 LeeBoy Motor Grader (A55218)
1982 LeeBoy Motor...
20 ft. Shipping Container (A53117)
20 ft. Shipping...
2018 JLG G5-18A (A50123)
2018 JLG G5-18A...
2020 CATERPILLAR 303.5E2 CR EXCAVATOR (A52705)
2020 CATERPILLAR...
