Grease Fittings Not Taking Grease
   / Grease Fittings Not Taking Grease #1
Aaron_D
Rhode Island
Bobcat CT230, Bobcat 325 Excavator, John Deere X300
Any of you having trouble with the grease fittings on the tractor (CT230) taking grease? The loader fittings have been taking grease with no issues but i've had no luck with the ones on the tractor.
Any tips?
   / Grease Fittings Not Taking Grease #2
Sometimes replacing the Zerk's or cleaning them out will help. :D
   / Grease Fittings Not Taking Grease #3
Seems to happen all the time{on mini ex} dirt is the monster. Just have to clean them out. If that doesn't work time for a new zerk
   / Grease Fittings Not Taking Grease #4
Think I remember posts in the past where they used a small nail to poke in and get the zerk to accept grease
   / Grease Fittings Not Taking Grease #5
Northern Tool sells a tool to clear reluctant fittings. It is a tube with a close fitting plunger. You fill the tube with oil, put the tip on the fitting and hit the plunger with a hammer. Used to be called a Dynamiter, every service station had one. That was in the days when service stations actually serviced vehicles.
Smilinjak
   / Grease Fittings Not Taking Grease #6
Smilinjak
I have used a similar tool for 30 years + and they work great. Word of caution, be careful on zerks on the angle. You can easily break those off when you hit the tool with a hammer. Ken Sweet
   / Grease Fittings Not Taking Grease #8
My concern with driving the dirt/old grease in would be driving that crap into the area ya wanna keep clean. Take the zerk out before driving the stuff thru it.
I used a can of break cleaner yesterday....remove the zerk, & use the straw to wash it out from the inside, then re-install.
   / Grease Fittings Not Taking Grease #9
I've had to replace four zerks on my CT335 in the last year and half, two on the loader and two on the tractor. The zerks looked clean and the balls would push down, but they would not take grease. I keep some zerks on hand so it is not a big deal. Easier to replace than futz with 'em.
   / Grease Fittings Not Taking Grease #10
My tool is called the "Rejuvenator." I just used it today to unclog two fittings on my loader.
There have been other posts on this subject, elsewhere. These unclogging tools seem to get a bad rap (pardon the pun), but I've used the Rejuvenator five or six times and it's done the job each time. One criticism is that dirt may be forced into the bearings. Well, maybe, but something tells me the risk of this, or the impact of it, is truly overblown.
It takes a little finessing but you get the hang of it. Sometimes you have to repeat the operation several times.
Be sure to bleed any air from the oil chamber. Just squirt a little oil out.
Another tip is to take pressure off the part the grease fitting serves. For example, don't try to unclog a fitting on a loader with the loader up in the air!
Finally, don't tap too hard. A steady, firm tap is what you want, to slowly force the oil in.
I don't mind "futzing." At least I don't have to futz around trying to research and buy the right-size zerk.
2005 Pierce Enforcer Fire Truck (A50323)
2005 Pierce...
2014 Chevrolet Equinox SUV (A50324)
2014 Chevrolet...
1968 CHEVROLET C10 1/2 TON PICKUP TRUCK (A51222)
1968 CHEVROLET C10...
2006 CATERPILLAR 330DL EXCAVATOR (A51242)
2006 CATERPILLAR...
2020 INTERNATIONAL LT625 DAY CAB (A51222)
2020 INTERNATIONAL...
2018 John Deere R4038 Self Propelled Sprayer (A50657)
2018 John Deere...
