My 1966 Massey 135 Tractor (Pics)
   / My 1966 Massey 135 Tractor (Pics)
Well that's pretty gross. That sleeve looks pretty corroded, hard to determine the extent from a photo though. Good decision :thumbsup:
There was only very minor corrosion at the bottom of the cylinders. The camera makes it look much worse than it really is.
Today, I removed the engine block from the tractor. It took a bit of effort, but it wasn't too bad overall. The engine is sitting on a piece of plywood until I remove the clutch assembly and flywheel so I can mount the engine block to the engine stand for the rebuild.
Also, I placed an order with a local dealer for the engine rebuild kit and other needed parts, they should be here in a week or two, then the real fun begins. As a word of advice to anyone who is looking for parts, always be sure to check with several dealers in your area, because some of the online vendors aren't as cheap as they appear to be. For instance, on the parts I've ordered, one of my local dealers sells the exact same parts for roughly 10-20% cheaper. Granted, some dealers are over priced, but not all of them, much to my surprise.
   / My 1966 Massey 135 Tractor (Pics) #213
Great thread! I had noticed this thread a few weeks ago, but never took the time to read until tonight. Started at day one to present, very interesting and an enjoyable read!
You know, you keep "expanding" the scope of this project.....I bet before it's done you are opening up the rear and going thru the backside!!!
You know those hydraulics bleed down in 15 minutes....bet those brakes could use some work...haha. Just ribbing you a bit. :)
Keep up the good work, nothing like a good tractor project for therapeutic purposes.
   / My 1966 Massey 135 Tractor (Pics) #214
consider doing the trans input shaft seal.. and of course you will be doing rear main. inspect clutch and flywheel, and ring gear at this time as well.
I'm glad you enjoyed reading it. Stay tuned, there is much more to come. Oh, and the brakes and hydraulics are on the to-do list, although they'll have to wait since I've blown my budget on the engine. :)
Great suggestions, and they're all definitely on the to-do list, especially the rear main and transmission input shaft seals.
Today, I finished stripping the engine block by removing the crankshaft, camshaft, and tappets. Getting the rear main cap off took a lot of time and required great care to avoid damaging anything.
The following pictures are of the engine block as it hangs upside down, just outside of my garage door, soaking in degreaser. After the degreaser has done it's job, I'll hose it down and wash it in a mild soap solution, before using my air hose to blow all the water off. Note that I'm using Gunk engine degreaser rather than oven cleaner, because Gunk won't harm the primer I've already applied and oven cleaner is too corrosive to risk any of it getting trapped in the oil passages.
   / My 1966 Massey 135 Tractor (Pics) #218
Hello Massey,
That is some nasty looking stuff in there. I don't think I will ever use stop leak again. How hard was it to pull the sleves and did it require any special tools?
v/r
Mike
   / My 1966 Massey 135 Tractor (Pics) #219
GOTTA love glyptol
How hard was it to pull the sleeves and did it require any special tools?
The sleeves weren't difficult to remove, but pulling them does require a sleeve-puller tool. The tool can be somewhat expensive, so I made my own using some scrap steel and a long threaded bolt.
2023 EAST TEXAS TRAILER (A52472)
2023 EAST TEXAS...
2019 POLARIS RANGER XP PROSTAR 900 HD DOHC UTV (A51406)
2019 POLARIS...
2025 New/Unused LandHero 16in Concrete Cutter (A51573)
2025 New/Unused...
2023 JOHN DEERE 8R310 LOT NUMBER 202 (A53084)
2023 JOHN DEERE...
2019 KEESTRACK K6 SCALPING SCREENER (A51246)
2019 KEESTRACK K6...
2016 John Deere 318G Skid Steer Loader (A51573)
2016 John Deere...
