1710 4 wheel drive shifter issue
   / 1710 4 wheel drive shifter issue #1
couger94
Alden NY
Ford 1710
Hi everyone, I am a newbie to this site and to tractors in general. I bought a 1986 ford 1710 4x4 diesel. It has around 700 hours and a loader. It is in fantastic shape. The problem, I have only been able to shift it into 4 wheel drive once. I am pulling till my shoulder is about to pop out and it only has gone in once. Has anyone ever run into this problem and where should I start to diagnose it. I thought about removing the lever (plate on top of the tractor that it runs through) to see if there was a problem. I have tried to creep it and I am keeping the RPM's low. PLEASE HELP I am paranoid that I just threw my money in the fireplace.
Jim
   / 1710 4 wheel drive shifter issue #2
Jim
Jim,
You should not be forcing it as it might cause more problem. Look the PDF attachment below. Look at items 15,16,and 17 that make your shift fork mechanism. # 17 is your detent ball that keep the the 4wd from jumping out . Remove the cover slowly and carefully and check condition of the detent ball and spring. I bet ya that's where your problem lies. Ball out of round, broken spring and things like that. I had the same issue with my gear shifter that pretty much used the same mechanism. I do not 4wd on my 1700 though.
JC,
  • 1710- 4wd diagram.pdf
   / 1710 4 wheel drive shifter issue #3
Another solution might be to shift while rolling and clutch depressed. Make gear alignment easier.
Russell
Hi, thanks for the input. Jones I have tried that to no avail. JC I can't thank you enough but if I could ask another question and I again apologize if it is a dumb one. How willi know if it is the ball out of round or a bad fork? Is the fork viewable once the cover is off?
Kawasaki KLX140L Dirtbike (A59225)
Kawasaki KLX140L...
2016 TRAILSTAR 40FT DUMP TRAILER (A56129)
2016 TRAILSTAR...
2022 Chevrolet Silverado 4x4 Crew Cab Pickup Truck (A56858)
2022 Chevrolet...
2018 Dodge Charger Sedan (A56859)
2018 Dodge Charger...
2015 CASE 621F WHEEL LOADER (A58216)
2015 CASE 621F...
Pratt 8.5ft Flatbed Tilt Trailer (A55787)
Pratt 8.5ft...
