I hate new fuel cans so here is what I did.
   / I hate new fuel cans so here is what I did. #1
Diamondpilot
Super Star Member
Daleville, IN
Jinma 254/284 Ford 861 Powermaster at work
I keep 30 gallons of fuel on hand and I hate the newer cans. Here is my fix. I used standard valve stems with the schrader valve removed. I drilled a 1/2" hole on empty dry fuel cans. Then with a piece of balling wire fish it though the hole drilled from the main hole. Pull it through with a valve stem took and seat it.
For the newer style can with the spring loaded fill neck I disassembled it and used some 5/8" plastic chair leg caps.
Chris
   / I hate new fuel cans so here is what I did. #2
Chris
I understand the schrader valve well enough.. but the last part about the 5/8 chair leg caps.. I don't understand at all. Pictures? ( I hear tell they are worth about 1000 words:) )
James K0UA
   / I hate new fuel cans so here is what I did. #3
Yep, I think we've all installed the valve stems based on a thread or two on the site... I'm with James, what's up with the caps? Are those the little yellow thingies in the pics? If so, that makes me think of the threads about fishing stuff out of your diesel tank :confused3:
Look at the second pic. I used the cap to close off the fill neck after I gutted it of all the spring loaded crap.
Chris
   / I hate new fuel cans so here is what I did. #5
Chris
Oh I see... I am getting along OK with my lever action Blitz.. (they dont make them any more, now it is a push on the edge of the filler neck to actuate thing). I did remove the safety though.
James K0UA
Here is a pic to help out.
Chris
   / I hate new fuel cans so here is what I did. #7
Chris
Yeah that is one of the new ones the stores are full of.. I did not want one of those.. I found an old stock lever action can, in a low volume store, and it works pretty well. Especially if you pull out the safety mechanism. Of course yours probably works pretty good now.
James K0UA
James K0UA
Add a vent like I did with the valve stem and it will work great.
Chris
   / I hate new fuel cans so here is what I did. #9
kudos !!! :thumbsup: hopefully the feds will take notice and change the darn mandates on fuel cans.....
   / I hate new fuel cans so here is what I did. #10
Unless those black plastic chair leg caps are made of HDPE (which I doubt), they likely will not hold up to gasoline well.
DEWFPO
2021 Delta Redirective Crash Cushion 75000 (A51692)
2021 Delta...
2013 WABASH 53x102 DRY VAN (A53426)
2013 WABASH 53x102...
POWER LINE 180 LOT IDENTIFIER 82 (A53084)
POWER LINE 180 LOT...
2023 JACTO ARBUS-1000 LOT IDENTIFIER 66 (A53084)
2023 JACTO...
UNUSED AGT 3 PT 82" ROTARY TILLER (A51248)
UNUSED AGT 3 PT...
