Need suggestions for cleaning 55 gallon plastic drums.
   / Need suggestions for cleaning 55 gallon plastic drums. #1
ka41
Louisiana
2009 L5240HST
I just purchased some 55 gallon plastic drums off CL and need to know what to use to clean the inside. I will be using 2 of them for diesel storage. I think the two I will be using had previously been used for storing Royal Purple oil. They do not have lids just two bung holes. So what is the best way to clean the inside?
   / Need suggestions for cleaning 55 gallon plastic drums. #2
Ok I will ask the first dumb question. What is CL ?
   / Need suggestions for cleaning 55 gallon plastic drums. #3
CL stands for CraigsList
   / Need suggestions for cleaning 55 gallon plastic drums. #4
There is probably no need to clean them if they had oil in them. Just empty out as much of that oil as you can before filling with diesel fuel.
For piece of mind I would like to clean the inside. Koamfps I'm sorry for abbreviating CL. Just lazy I guess.
   / Need suggestions for cleaning 55 gallon plastic drums. #6
Simple green and water. Triple rinse. Dry with clean dry air or nitrogen. It's how we do it.
   / Need suggestions for cleaning 55 gallon plastic drums. #7
Oh and with a pressure washer
   / Need suggestions for cleaning 55 gallon plastic drums. #8
Use what they use to disinfect and clean holding tanks in RV's
Dawn liquid, Borax, calgon water softener, Bleach, a cup each. Fill up the tank let it sit, rinse several rimes.
   / Need suggestions for cleaning 55 gallon plastic drums. #9
Or just slosh a bit of diesel around in there pour it out into a bucket to use for burn piles or whatever and the drum should be clean AND not have any water in it.
   / Need suggestions for cleaning 55 gallon plastic drums. #10
Are you going to put a pump or anything on these drums? I would be interested in any details on how you will use them.
(INOP) VOLVO L70H WHEEL LOADER (A51243)
(INOP) VOLVO L70H...
UNUSED FUTURE FT2P 12 VOLT PUMP (A51248)
UNUSED FUTURE FT2P...
2008 Ford E-250 Cargo Van (A50323)
2008 Ford E-250...
2021 JOHN DEERE CP690 LOT IDENTIFIER 204 (A53084)
2021 JOHN DEERE...
20 ft. Shipping Container (A53117)
20 ft. Shipping...
2015 UTILITY VS2RS 53FT REEFER TRAILER (A53426)
2015 UTILITY VS2RS...
