HTF parts MF 135
   / HTF parts MF 135 #14
Sparex in the UK is one manufacturer of aftermarket parts, another is Mian in Pakistan, not sure that SSB uses either predominantly.
If the diagram looks close enough that it will fit with slight modification that's better than starting from scratch, assuming it's not too costly.
Good luck!
   / HTF parts MF 135
Good luck!
I found out that Sparex's home office is here in the states. They are international. BTW I found one of those elusive heat shields from a dealer in Wisconsin who had one on the shelf rust free. He's also looking for that battery tray/dashboard piece. Still no luck on the pre-cleaner. My new gauges came in. Replacing them all. Mine used some type of transformer which is long gone. I'll box these up. They fog up anyways, probably trash em.
Was busy today prepping the dash. I removed it and ground all the paint off and will do a tiny bit of body work and a tad of filler. Putting a 12v waterproof accessory plug on the dash too.
It's been in the upper to mid 90's here so I do a bit in the evenings when it's cooler. -robert
   / HTF parts MF 135 #16
I got a good used one from the bone yard at my local Massey dealer. They have quite a few 135 they are parting out, I can check it out for you. Jim
   / HTF parts MF 135
Hi Jim, are you talking about the battery/dash platform or the pre-cleaner cap. Either one or both would be sweet. Both are rare to find. If it' not too much trouble I would certainly appreciate the information. Thanks - Robert
ITEM LOCATION (A53084)
2016 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A51692)
2016 Peterbilt 320...
2018 FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A53426)
2018 FREIGHTLINER...
UNUSED Portable Bathroom (A53117)
UNUSED Portable...
1972 Baker 30ft Pole S/A Towable Trailer (A51694)
1972 Baker 30ft...
2017 John Deere HPX615E Gator 4x4 Utility Cart (A51691)
2017 John Deere...
