I hate new fuel cans so here is what I did.
   / I hate new fuel cans so here is what I did.
DEWFPO said:
Unless those black plastic chair leg caps are made of HDPE (which I doubt), they likely will not hold up to gasoline well.
DEWFPO
Thanks. If they don't I will replace then. It was $1.09 for a 4 pack.
Chris
   / I hate new fuel cans so here is what I did. #12
One of my revisions involved a rubber grommet and golf tee from my accumulation of junk. That worked awhile until the rubber rotted away. It now has a stainless bolt on wheel Schrader valve. Maybe these rubber washers will hold up better in diesel.
   / I hate new fuel cans so here is what I did. #13
Wait until Obama catches you and sends the gas can police out after you!
:confused3:
   / I hate new fuel cans so here is what I did. #14
The EPA should fine itself for all the gas that has gone into the environment because of their stupid cans.
   / I hate new fuel cans so here is what I did. #15
Ironic isn't it:)
The law of unintended consequences
James K0UA
   / I hate new fuel cans so here is what I did. #16
Diamond I did the same thing a while back and I used a replacement rubber bumper they sell for the bottom of a cane,it's lasted years.
Brian
   / I hate new fuel cans so here is what I did. #18
A couple years ago I did the valve stem trick and I recently found some short low profile ones that I think are for golf carts. They only stick up about 5/8". The regular ones work fine too. I have 7 cans using them. Sad thing is the cans last forever but the spuots don't.
   / I hate new fuel cans so here is what I did. #19
I think the caps will hold up well enough but thats just my :2cents: They are just to keep gas from sloshing out. Usually I never even cap that end because unless you are off roading and/or hauling inside a car, you may loose two drops of fuel in the bed of the pick up. Most of my gas cans, those caps are either lost or broke off:confused2:
   / I hate new fuel cans so here is what I did. #20
Here is a pic to help out.
Chris
Excellent idea! Was it an easy thing to disassemble the new style spout without breaking it? Anything particular to watch out for?
Theo
2017 John Deere TX Gator Utility Cart (A51691)
2017 John Deere TX...
BUSH HOG 7007 LOT IDENTIFIER 103 (A53084)
BUSH HOG 7007 LOT...
(1) UNUSED 7000# DROP AXLE W/ BRAKES (A51247)
(1) UNUSED 7000#...
UNUSED JCT HYD AUGER (A51248)
UNUSED JCT HYD...
2016 Tesla Model S 85D Long Range AWD Sedan (A51694)
2016 Tesla Model S...
2002 Fleetwood Expedition 36ft Class A Motorhome (A51694)
2002 Fleetwood...
