slowzuki
Elite Member
- Joined
- Sep 19, 2003
- Messages
- 4,156
- Location
- New Brunswick, Canada
- Tractor
- Kubota L5030 HSTC, MF 5455, Kubota M120, Allis Chalmers 7010
Similar to the sedans, the first generation of suzuki sidekick had a 2500 lb tow rating here in Canada, I'm guessing in europe it was 3500 lbs with braked trailer. In the US I believe the tow rating was reduced to 1500 lbs, and I think the GM branded models maybe even 1000 lbs.
Some of it is marketing, in europe, the hp to weight ratios are always lower. No one expects to do 0-60 in 7 secs in a family car, and they expect slow hill climbs with trailers. People seem to want 300 hp commuters here, with an ignorant driver and a trailer that is going to damage drivelines and over heat engines that were never designed to operate at peak power output for long.
In US trucks, we have seen the climb of tow ratings in the last 20 years, to match how people have actually been using them. My 2001 F350 superduty originally came with about a 5000 lb tow rating similar to the previous models. To get the higher 12,500 tow rating, all I needed was the larger motor c/w with matching radiator. It had the same 4r100 auto trans, the same driveshaft, same axles, brakes, frame, transmission cooler, etc etc. The truck is very happy towing 16,000 lbs despite the original rating and you see the they had revised the factory rating to much higher even before the bigger brakes of 2005.
