Ruined my PTO Shaft
   / Ruined my PTO Shaft #1
powwowell
Member
Deep Run, NC
John Deere 1026R
I messed up and cut my PTO shaft off, too short. I have a Woods RM360 mower. Will other brands of PTO shafts work with my mower?
   / Ruined my PTO Shaft #2
Most any will work, as long as they're the correct length...an caveat though. Some gearboxes don't use the standard 1.375 x 6 spline stubshaft. For example, my Woods chipper uses an implement connection that has a milled flat for set screws. Another thing is the shear pin (bolt), if used.
Can't hurt to see what Woods charges for a replacement. Otherwise, try Tractor Supply and Agri-Supply.
BTW, Agri-Supply also sells a PTO Adapter for about 20 bucks. It goes on the tractor end and adds about 4"...that might work for you.
   / Ruined my PTO Shaft #3
You could just buy the inner & outer shafts & reuse the yokes. Check out ptoshafts.com.
The most shaft sections are fastened to the yokes with a roll/split pin.
P.S. you might be able to get away with just replacing 1 of the shaft sections
   / Ruined my PTO Shaft #4
I have had good luck buying a replacement shaft from Farm Equipment recyclers.
   / Ruined my PTO Shaft #5
TSC had a shaft that fit the RM360, I bought one there last year, or 2 yrs ago for mine.
   / Ruined my PTO Shaft #6
just weld it back together?
   / Ruined my PTO Shaft #7
That would certainly be worth a try. You'd have to work at keeping it straight of course but I think it's do-able and what have you got to lose? Even if it isn't completely satisfactory, it would be a good learning experience....unless the PTO shaft can be repurposed on another piece of equipment where it would be the right length.
   / Ruined my PTO Shaft #8
   / Ruined my PTO Shaft #9
I found that you can usually buy the whole shaft cheaper than trying to buy just tubes, or just yokes.
I got mine from what is now haytools.com. It looks that for $120, you can get a complete series 4 shaft, with 1-3/8 splined on both ends, and 47"-67" length.
And They can get other stuff beyond what is listed. PTO Shaft and PTO Shields
INOP-NON-RUNNING 2008 Peterbilt 340 Water Truck, VIN # 2NPRLN9X78M769162 (A54865)
INOP-NON-RUNNING...
200356 (A51406)
200356 (A51406)
2016 R and R Products 331 LP Reel Mower (A55851)
2016 R and R...
2004 Ferrara Apparatus Pumper Fire Truck (A55852)
2004 Ferrara...
2011 Genie Z80 Man Lift (A54865)
2011 Genie Z80 Man...
2016 FREIGHTLINER  CASCADIA (INOPERABLE) (A55745)
2016 FREIGHTLINER...
