dfkrug
Super Member
- Joined
- Feb 3, 2004
- Messages
- 7,660
- Location
- Santa Cruz Mtns, CA
- Tractor
- 05 Kioti CK30HST w/ Prairie Dog backhoe, XN08 mini-X
This thread will show the repair efforts I went through to fix a sloppy
FEL on my 4300 ex-rental tractor. This is a chapter in my refurbishment
project on this tractor:
http://www.tractorbynet.com/forums/parts-repairs/247806-2001-john-deere-4300-hst.html
This loader is the smaller of 2 OEM units available from JD for the 4200/4300/4400
tractors, as well as some of the 4x10 CUTs. The bigger one (430) has larger
cylinders with larger rods, as well as "kidney links" on the bucket end of the
boom. Those 2 improvements would reduce the chance of needing some of
these repairs, IMO.
The most obvious problem with my FEL was its looseness. I could shake the
vertical masts left and right and get more than 1/2" of movement with
the boom at rest. The JD quick-attach bucket brackets had been bent and
repaired, probably from operating the boom without both brackets fully
engaged on the bkt, or possibly when a pin fell out.
Furthermore, the bucket itself was bent, some cylinders leaked, and one
had a bent rod.
The good news: the boom arms were not bent. I have seen bent booms before,
caused by renters ramming the tractor into immovable objects. That's
a difficult fix.
When I got the FEL off, the first thing I noticed was how worn the subframes
are. Even the locating key has a deep groove in it.
The mast itself is cast steel at its base (3rd photo), with 7 contact areas.
Each was significantly worn or mushroomed. 'A' indicates where the
locating key goes, and it too had lost a lot of material. I filled it in with
a weld; it was about 1/4" deep.
these repairs, IMO.
had a bent rod.
a difficult fix.
