Question on kubota spec sheet-whats this mean?
   / Question on kubota spec sheet-whats this mean? #1
Piston
Elite Member
New England
Kubota L4610 Hitachi UH083LC
I was looking at a PDF printout that compares the M6040 series to some other manufacturers and have a question on something I saw. When looking up the weight, it lists it as 4,079 lbs for the open station.
In the right column that is the "kubota advantage" section, it lists...
"Lighter psi ground compaction. Field ready at 180% base weight for heavier work"
What does this mean?
   / Question on kubota spec sheet-whats this mean? #2
"Lighter psi ground compaction"- I think they are saying it is lighter so it will not compact the ground as bad other tractors in its class. I don't know about the field ready part.
   / Question on kubota spec sheet-whats this mean? #3
Maybe Kubota is saying that if you want to use that tractor in the fields for farming, that it should be ballasted 180% of it's base weight. In other words, if you are going to use the tractor, it needs to weigh 7342lbs. Makes sense to me, more weight, more work can be done. But then there are others that totally disagree with that scenario. :confused3:
   / Question on kubota spec sheet-whats this mean? #4
I'm inclined to agree with MtnViewRanch, everything around here in the fields has added weight of some sort, often combinations of weights.
   / Question on kubota spec sheet-whats this mean? #5
I never really looked at that before but it is something that you can add 80% of the original weight to the tractor and they would still handle it!
   / Question on kubota spec sheet-whats this mean? #6
That is exactly what I got out of reading it. The "advantage" is you start out with a lighter tractor for low compaction if you need that, but can be ballasted for field work. If you started out with a heavy tractor to begin with, then you would not have that advantage. Marketing people do not always make thing perfectly clear.
James K0UA
   / Question on kubota spec sheet-whats this mean? #7
It's like bring your own beverages (BYOB) but with weights.
   / Question on kubota spec sheet-whats this mean? #8
Yup. its saying that you can add 80% of the machines weight in ballast, where you need it, depending on your application.
That makes sense. At first I didn't think it meant to add that much weight because I thought it sounded like it would be too much, but I guess not. I suppose the FEL would be a good chunk of that weight needed as well.
Thanks for the answers fellas.
Does Kubota offer a 540E option? More specifically on the M7040? (I imagine the 5040,6040, and 7040 all have the same available option)
If not, did they come with the option of a 1,000rpm PTO? Is operating a 1000rpm pto at 54% of the rated engine speed for 540, essentially the same idea as a 540E? In other words is it okay to do that, and would it be effective?
2011 John Deere 120D (A47477)
2011 John Deere...
2012 Chevrolet Silverado 3500 HD Enclosed Service Truck (A52377)
2012 Chevrolet...
2021 Harley-Davidson FLHP Motorcycle (A51694)
2021...
2012 Cub Cadet 17YI2ACP056 Zero Turn 50in Lawnmowe (A53117)
2012 Cub Cadet...
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A54313)
2018 FREIGHTLINER...
