Splined to keyed shaft adpater?
   / Splined to keyed shaft adpater? #1
mooseracing
I picked up skid sprayer that the pump was pretty rough on, so I am replacing the pump and some ******** :)D) ordered a pump for a keyed shaft. So are there adapters out there to go from splined to keyed? Otherwise I am going to swap cranks. More hassle then I was expecting, but I hadn't run across a splined, only keyed and threaded.
If it matters this is on a Honda GX160
   / Splined to keyed shaft adpater? #2
So are there adapters out there to go from splined to keyed? If it matters this is on a Honda GX160
So I'm assuming the splined motor end is male. Would this fit? Surplus Center - 5/8 9T SPLINED COUPLING 03-32-00027
You'd then have to bore it out to press in a shaft to go in the female pump section, if that's the type of pump you got. Otherwise, if you're joining two shafts, I'd be tempted to switch over to using a flex coupling. Just pick the halves that have the right ends on them, perhaps something like these:
Surplus Center - 5/8" 9 TOOTH SPLINED L-095 JAW COUPLING HALF
Surplus Center - 5/8" L-095 JAW COUPLING HALF
and the spider:
Surplus Center - BUNA-N INSERT FOR L-095 & L-090 JAW COUPLING
Does that at least get you close?
   / Splined to keyed shaft adpater? #3
I'm building a 3PH leaf blower. Part of this requires a jack shaft run by the PTO. The local farm store had a male spline x female 1" keyed, and is something commercially made as a pump adaptor if I recall the tag on it. It's around 6" in length. If this is something you are interested in I can get more info when I get back to work on Monday. If you're in a hurry you can call the store:
PaulB Hardware - Serving Lancaster County, Ephrata, Lititz, Pa. | Specializing in Tools, Agricultural/Industrial Parts, Electrical, Paint, Plumbing and more for the contractor, farmer and homeowner
John Deere 335 Round Baler (4ftx4ft) (A52748)
John Deere 335...
2018 XCMG XE210CU CRAWLER EXCAVATOR (A52576)
2018 XCMG XE210CU...
2009 Chevrolet TrailBlazer Multipurpose Vehicle (A51694)
2009 Chevrolet...
2015 KENWORTH T800 (A52472)
2015 KENWORTH T800...
