New(old) sa200 lincoln
   / New(old) sa200 lincoln #11
Does your machine have a Marvel Schebler or Zenith carb? I've had the best luck with Zenith K13720 carbs. Either way your local NAPA parts house can get you a re-build kit.
AMERICAN ELECTRIC IGNITION - ZENITH CARBURETORS
I got tired of dealing with the old starters, all my older machines are running these starters.
Marvel carb. The starter I ordered looks similar to yours. High torque ( its what Bill's uses at their shop)said they have good luck w/ them. I will keep you posted .thanks
   / New(old) sa200 lincoln #13
Always replace old starter/battery cables with heavier guage new cable. Make sure your ground cable connections are good too.
Appreciate the info guys. Got the starter(nothing like the one I have). I guess the big post is+ and the small terminal is - ? Is that correct? Any easy way to wire this high tech starter up? Mine looks like the one shieldarc has.
   / New(old) sa200 lincoln #15
Here you go. I just happen to have one out of a machine. Yes large post goes to + side of battery.
First off thanks everyone for the info. Weird thing- I have been trying to start this welder for 2 days. So I thought what the heck and put the plug wires on like it had a Bosch mag. Presto, it fired right up. How is that? Every web site I looked at for a Fm Mag was like shieldarc's. Am I missing something? Anyway its running. Do any of you guys and gals know where on the engine to hook up a water temp gauge? Head or block? Thanks again
   / New(old) sa200 lincoln #17
Here is a good place for a water gauge sending unit, but don't be surprised if you have to drill the plug out and re-tap the threads. If I remember correctly it is 3/8-inch NPT, might be 1/2.:confused:
Shieldarc, you are right. I broke my bit trying to get that plug out! Could I make a connection and put it in my top or bottom radiator hose? Maybe an inline pipe with a fitting?
Thats's cool. Thanks. I can make that work.
2017 PETERBILT 567 TRI-AXLE MID-ROOF SLEEPER (INOPERABLE) (A52472)
2017 PETERBILT 567...
NEW Fork Extensions (A53002)
NEW Fork...
2019 FORD TARNSIT CONECT CARGO VAN (A52577)
2019 FORD TARNSIT...
2020 Utility Trailer Manufacturing, 53' Trailer (A52384)
2020 Utility...
ARMSTRONG  10 FT DISC (A52472)
ARMSTRONG 10 FT...
BESTWAY LOT NUMBER 40 (A53084)
BESTWAY LOT NUMBER...
