Hydralics for front-end loader chatters when raising bucket...What is causing this?
   / Hydralics for front-end loader chatters when raising bucket...What is causing this? #1
Richard1942
California, KY
Ford 3000 Gas
I have a Ford 3000 4 cylinder tractor with a front-end loader. The hydralics chatter as I raise the bucket. What could be the problem here? Is this going to be an expensive repair? Could the repaor be tackled by a mechanically inclined do-it-yourselfer?
Thank you for reading.
   / Hydralics for front-end loader chatters when raising bucket...What is causing this? #2
Have you checked for air in the hyd's.
If so, the cyl will purge any air with use, but, if you have a suction leak, you are still sucking in air. Tighten all clamps and check hoses.
   / Hydralics for front-end loader chatters when raising bucket...What is causing this? #3
There was never a 3000 built that had 4 cylinders.
If you have a 730 industrial or similar with a crankshaft driven hydraulic pump and the frame as a reservior, your filter is probably plugged and/or the short sections of suction hose are delaminated and collapsing. Or your oil level is low or the oil is of the wrong viscosity. Bottom line, your pump is cavitating and if you run it that way for a prolonged period it will be trashed.
UNUSED CFG INDUSTRIAL H15R EXCAVATOR (A52706)
UNUSED CFG...
2020 VANGUARD CIMC 53FT REEFER TRAILER (A54607)
2020 VANGUARD CIMC...
2016 Case 821F Articulated Wheel Loader (A54811)
2016 Case 821F...
2016 CATERPILLAR 249D SKID STEER (A52705)
2016 CATERPILLAR...
2012 UNVERFERTH 10-INCH FRONT WHEEL SPACER FOR 10 BOLT HUB (A55301)
2012 UNVERFERTH...
1992 BOBCAT 743 SKID STEER (A52705)
1992 BOBCAT 743...
