1966 MF 135 gas contential generator question
   / 1966 MF 135 gas contential generator question #1
floridadan
Crystal river, fl
135 Massey
I am connecting the tachometer back to the generator, and a small spring fell out, any idea where the spring goes
I just can't figure this one out. Pls help!
Dan
   / 1966 MF 135 gas contential generator question #2
A small spring fell out from where? Pictures might help to identify it.
   / 1966 MF 135 gas contential generator question #3
Dan
Dan, is it the original generator and tractormeter/proofmeter/tachometer? Did this spring fall out of the tachometer on the rear of the generator? I don't think there is a spring that can fall out when you remove the cable on either end. Did you have the tachdrive on the rear of the generator apart? Does your generator look like the one below? I don't see a spring listed nor illustrated in the exploded view. -robert
   / 1966 MF 135 gas contential generator question #4
Dan
Dan, here's another picture of the tachdrive itself that attaches to the generator with three screws. I don't see a spring there either. -robert
   / 1966 MF 135 gas contential generator question #5
What about it Massey. You've had your generator all apart. Is there a spring somewhere that would fly out when you remove the cable?
   / 1966 MF 135 gas contential generator question #6
Found location of springs, it fits in the hole in the center, thanks, for the help. Florida Dan
TROY BILT PRESSURE WASHER (A51248)
TROY BILT PRESSURE...
(1) UNUSED 7000# DROP AXLES W/ BRAKES (A51247)
(1) UNUSED 7000#...
2015 Ford Taurus AWD Sedan (A51694)
2015 Ford Taurus...
2012 INTERNATIONAL PROSTAR +122 EAGLE 6X4 ROAD TRA (A51247)
2012 INTERNATIONAL...
Caterpillar 56in Excavator Bucket (A51691)
Caterpillar 56in...
