1966 Massey 135 Contental Gas, Butterfly wont open
   / 1966 Massey 135 Contental Gas, Butterfly wont open #1
floridadan
Crystal river, fl
135 Massey
1. When trottle handle is pulled down to increase speed, the govenor rod will not open the carburator ( butterfly).
Also I really appreciate the Generator Help, from everyone.
Florida Dan
   / 1966 Massey 135 Contental Gas, Butterfly wont open #2
Florida Dan
Dan, I would have thought one of the veterans 135 owners would have chimed in by now. Here's my take on this. You have a choke and a throttle butterfly. The upper chamber of the carb is controlled by a cable which during warm weather probably if left open and not needed on a cold start. At least not on mine. The throttle butterfly is attached to a rod running foward with a bolt yoke on the end which attaches to the governor. Unless you have a clip come loose it should move the throttle slightly when moving the throttle handle.
Dan in the second picture there is a rod #47 called the throttle rod. :D This rod attaches to the backside of your carb. Make sure this rod is attached. MAke sure one of the clips is not broken under the dashboard. Part #8
This illustrated can be downloaded by you by going to AGCO Parts Books and use the QUEST loggin. Type in 135 under type and make Massey Ferguson in the pulldown window.
It sounds like something has come loose. The illustration is my 1965. There are two listed under the Continental and two listed for Perkins. Pick the one that like your linkage before you print. Good luck. :thumbsup: -robert
Book 651199 pages/reference 72
   / 1966 Massey 135 Contental Gas, Butterfly wont open #3
Good advice given by Kid, once you've confirmed freedom of movement of the linkages and carb post what you've found. It could be a governor problem if everything else is as it should be.
2016 Hino 195h Truck, VIN # JHHSPM2H6GK001602 (A51572)
2016 Hino 195h...
Tires (A50121)
Tires (A50121)
Ran during check in. No longer running. (A51694)
Ran during check...
2002 International 9200i Truck (A52748)
2002 International...
2019 Chevrolet Tahoe SUV (A50324)
2019 Chevrolet...
Mahindra 2516 Compact Tractor w/Loader (RUNS) (A50774)
Mahindra 2516...
