2000 ford three point hitch
   / 2000 ford three point hitch #1
Varmint1
Deville,La
JD 1010, JD 970, Farmall Super A,Komatsu D20A-5,Ford 4500,Ford 4000 forklift,Ford 640 w/703 loader
My uncles 67 model 2000 ford 3 cyl. gas three point hitch only works if he moves the draft control and then it just lowers back down
   / 2000 ford three point hitch #2
time to buy an fo-31? service manual.. a 15$ top cover gasket and oring kit.. and pull the cover and adjust the linkages renew the orings and gasket..e tc.. might service the filter /oilwhile in that far as well.
   / 2000 ford three point hitch #3
Soundguy- Does a 1963 Ford 2000 have a filter in the 3 point lift system?
Thanks- Oldstuff
   / 2000 ford three point hitch #4
Thanks- Oldstuff
short answer.. no.
long answer: could be.
1, there was a dealer filter option available that used an external spin on filter.. they are exceedingly rare to find on that has that option.
2, if you are running some sort of hyd implement off the tractor hyds, if there is a return filter on that setup.. then defacto.. the system has a filter.
run of the mill 00/01/4 cyl 000 no filter..
(APPROX 24) 2" X 6" X 60" CHANNEL IRON (A51247)
(APPROX 24) 2" X...
UNUSED WOLVERINE GB-11-72W-72" HYD GRAPPLE BUCKET (A51248)
UNUSED WOLVERINE...
UNUSED AGT QUICK ATTACH 72" VIBRATORY ROLLER (A51248)
UNUSED AGT QUICK...
2008 DOOSAN G25 GENERATOR (A52472)
2008 DOOSAN G25...
2023 SMITH CHALLENGER SCM 400 SWEEPER (A51246)
2023 SMITH...
2014 GMC Sierra (A51692)
2014 GMC Sierra...
