Bush Hog 286 clean used 3 pt. shredder 6' (whats it worth ??)
   / Bush Hog 286 clean used 3 pt. shredder 6' (whats it worth ??) #1
pharmvet
North East TX
Ford 7710 II FWA, NH TB110 FWA w/ NH 46LB loader, JD 5303 2wd w/ loader
A buddy of mine offered me his clean used 286 Bush Hog shredder for $1250. It has front and rear chains. What is your opinion of that price? thanks
   / Bush Hog 286 clean used 3 pt. shredder 6' (whats it worth ??) #2
I bought same one two years ago for 1300. It didn't have chains and after I got it to the property discovered it need new stump jumper, 500.00. I would say go for it if it is in good shape and works. Ask to see it cut.
   / Bush Hog 286 clean used 3 pt. shredder 6' (whats it worth ??) #3
The 286 is a good medium-duty rotary, well made and strong. But rotary cutters can sometimes have a hard life.
A quick check you can do without it running is to rotate one of the blades to where you can mark or measure the height of its cutting edge - then rotate the other blade around to the same position and see if the blades are at the same height. If they are vertically off more than about 1/4" then something is bent and needs straightening to get a good cut. With a bent stump jumper the blades can be off 1" or more. While you are under there check all around the spindle for any evidence of oil leaking out of the gearbox. If it's dry, take out the fill plug and check to make sure there's oil in it. If it all checks out, buy it. A comparable new one is $2k or more.
   / Bush Hog 286 clean used 3 pt. shredder 6' (whats it worth ??) #4
Yes, check each blade's height. And that is a good price.
   / Bush Hog 286 clean used 3 pt. shredder 6' (whats it worth ??) #5
yes thats a great price for that shredder if its in good shape.new that shredder is prolly close to $3000 now.
Utility Tilt Trailer (A55787)
Utility Tilt...
96" X 53' FLATBED TRAILER (A52706)
96" X 53' FLATBED...
International 3414 Tractor w/Loader (RUNS) (A50775)
International 3414...
2015 Ford Transit Cargo Van (A54814)
2015 Ford Transit...
2019 Freightliner M2 106 8.5 CuYd Street Sweeper Truck (A53422)
2019 Freightliner...
Sterling AT (A55301)
