Buying Advice Kubota L3800 vs Mahindra 3616
   / Kubota L3800 vs Mahindra 3616 #41
MahindraDon: If you are still following this thread, I hope there are no hard feelings and my apologizes for comming down on you so hard. That was NOT my intent. But I do have a serious question that maybe you can answer as I cant find the spec anywhere. Specifically, I would like to know the following about the 3616 loader:
1. Lift cylinder bore diameter
2. Lift cylinder stroke length
3. Operating pressure for the system
Thanks[/QUOTE]
Lift Cylinder bore diameter is 2.00"
Lift Cylinder stroke length is 17.80", Extended length is 43.7" and retracted length is 25.9"
Operating pressure is just over 2,000 psi. It is rated at 2,050 to be exact
The tractor system rated flow is 7.7 gpm
Price Check on Cab models All have FEL and HST. Loaded tires
Mahindra 3616. - 26,000
Kioti DK35 - 25600. Last yr model
Kioti DK40 - 27500
   / Kubota L3800 vs Mahindra 3616 #43
Be sure you know what your getting. The 3616 and DK35 are very similar in size and HP. The DK40 is a frame up from either and MUCH more powerful than both. For that much more than a 3616 I'd be tempted to go for the DK40, if it still fits where you want it. The DK35 would be my second choice, nothing against the Mahindra as it is still a very fine tractor.
Some people who know more about each brand will be able to tell you more about how you are on price.
   / Kubota L3800 vs Mahindra 3616 #44
Price check on DK35seHST 19300 open station cab an extra 6200 so 25500 This was back in April
I bought the open station one.
James K0UA
What loader did you get? Just drove by Kioti dealer. Saw a DK45 cab. What a nice machine. Cab was roomy, flat floor, really nice seat. Think we may have found a keeper. Just smaller hp
   / Kubota L3800 vs Mahindra 3616 #46
That DK is a beast..You will love that 2700 lbs of brute force of lift..
   / Kubota L3800 vs Mahindra 3616 #47
Thanks. I was just wondering how they got the 1600# lift and weather it was just marketing hype or if it actually had larger cylinders.
The L3800 (just incase anyone was wondering) has 1.77" bore cylinders and 2350psi.
Kioti DK40 - 27500
I still think you should price a grand L kubota just for curiosity.
   / Kubota L3800 vs Mahindra 3616 #48
A DK45 will be even more powerful, and more money.
I agree with LD1 though. Price out the 'Bota before going any further to get all options on the table. It would be a L3540 in comparison to the DK35, an L4240 in comparison to the DK40 and an L4740 in comparison to the DK45 if I recall correctly. (This is without going to the Kubota site as someone who is not highly educated on them, let's see how I did ;))
   / Kubota L3800 vs Mahindra 3616 #49
The ck35 is closer to a 3616 isn't it?
Spec wise Yes. Price wise no. Kioti is a lot more bang for buck
2017 Nissan NV200 Cargo Van (A53422)
2017 Nissan NV200...
2017 Ford Explorer AWD SUV (A51694)
2017 Ford Explorer...
2008 Volkswagen Passat Sedan (A51694)
2008 Volkswagen...
2016 Komatsu PC210 LC-11 Excavator (A53117)
2016 Komatsu PC210...
2003 500 BBL FRAC TANK (A53843)
2003 500 BBL FRAC...
GALAXY - SET OF 19.5L-24 INDUSTRIAL R4 TIRES (50% TREAD) (A53473)
GALAXY - SET OF...
