1652 won't start
   / 1652 won't start #1
tractorski
southern Vermont
Branson 3510
I was working with the tractor, i put the front end in the garage to take the loader off. I got the loader unhooked and shut the tractor off to un hook the hydraulic lines. went to start it back up and it won't start. Motor turns over fine and I can hear the fuel pump working, but it won't fire. anyone have any ideas? it has plenty of fuel. I checked, cleaned any electrical plugs and checked the fuses.
   / 1652 won't start #2
It's likely your seat safety switch. Bounce on your seat a couple times and try starting again. If that fails, unplug the connector on the bottom of your seat and put a jumper wire across the terminals of the wires leading to the tractor to test if the safety switch is malfunctioning. Good luck. Steve
   / 1652 won't start
Well, it was the injector solenoid, I had to wait for it to fail completely before the dealer could find the problem. Done.
Sent from my iPad using TractorByNet
   / 1652 won't start
Yes, the tractor is 2 years and 11 months old, I just made it by a month. I am sure the cost of the flatbed ride is not covered though.
2017 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A55973)
2017 Chevrolet...
2022 CATERPILLAR D3 LGP CRAWLER DOZER (A52709)
2022 CATERPILLAR...
2018 ALLMAND BROS, INC. ALLMAND BROS, INC. (A55745)
2018 ALLMAND BROS...
2020 DRAGON 150BBL ALUMINUM (A58214)
2020 DRAGON 150BBL...
2025 GIYI GY-SZYMJ Hydraulic Stump Grinder Mini Skid Steer Attachment (A56857)
2025 GIYI GY-SZYMJ...
2015 Ford Fusion Hybrid Sedan (A56859)
2015 Ford Fusion...
