Rarer/less-known/different welding rods I have
   / Rarer/less-known/different welding rods I have #1
LD1
Epic Contributor
Central Ohio
Kubota MX5100
Well, not really I have, but have access to at work.
I was cleaning out the welding supplies at work and came across some different rods that I have never heard of. So ofcourse I googled them and did a little reading, but I am more curious as to you guys' experiences with these rods or if you have ever heard of them.
They are the following
Super Missle Rod (red flux)
x-ergon #106 (grey flux)
eutectrode 680 (blue flux)
So...what say you'all about these rods and when/where have you used them? how did you like them?
   / Rarer/less-known/different welding rods I have #2
I have never heard of any of them. Any AWS classificationa and SFA numbers on them
   / Rarer/less-known/different welding rods I have #3
Missle weld is some type of maintenance rod for various metals ( I have some and have only used a couple rods) and is made by Harris if you want to look it up
Nope
Ineresting though, the x-ergon 106 has a MUCH higher tensil and yield strengths than 7018, and not sensitive to moisture, and welds like butter:thumbsup:
One may then ask: why isnt it popular like 7018
Well, the reading I have been able to find is that rods like these I mention are propritary and use some "secret" recipe, and thus without wanting to give that away, these rods arent certified and can not be used for "code" work as a result. Even IF they may be a better and stronger weld.
I did do some fooling around sticking metal together and breaking it, and all 3 above plus 7018 and really wasnt much difference in any of them as far as strength. This was in a simple butt weld with 1/8" gap and 1/4" plate. Welded one side only and then broke in the vice with the hammer bending the weld back over itself(weak direction). Again, not a noticable difference at all in terms of strenght IMO. But of all of them, the super missle weld was probabally the easiest rod to lay. It laid down like a 6013 or 7014 would.
   / Rarer/less-known/different welding rods I have #6
Seems as I remember it being a pain to weld vertical up. But I could be wrong, last time I used any must have been 1988.
That could be. I only did a horizontal flat with it and it was nice.
We dont do much out-of-position welding at work. Everything is usually dont in the shop on the bench where it can be rolled around to get "in-position". And we mostly mig stiff anyway. We rarley use the stick anymore since we modified the mig to be hoisted in the air with a forklift. Cause before that, any high work was stick because the leads on the mig only reached so high. Now the stick is reserved for only old and dirty, or cast.
   / Rarer/less-known/different welding rods I have #8
I have run tons of the Super Missile Weld. We used it for welding cast steel, (not cast iron). It is a high class 312 stainless steel. I'm guessing around $35.00 a pouSuper Missileweld | The Harris Products Group
Supper Missile is in fact a 312 SS with a fancy flux. Heavily priced for the nich market. 120K tensile flows like mercury. We always sold it to weld steel to cast steel or other dis similar metals. I have a bunch I would sell but you can buy Stoody Versalloy for $8.00# and it's the same rod.
That makes it a tougher rod than even the popular 7018. Nice.:thumbsup: And dont have to jump through hoops to store it. I couldnt find the tensile strength on it. But I didnt look hard either:rolleyes:
   / Rarer/less-known/different welding rods I have #10
I used to sell all the Harris products. Some of the more nich or smoke -n - mirrors material was Welco 52, Al-Core and Cor-Al for Aluminum, 14FC,17FC for silver brazing with gaps. All the Ni Rods. 28,55,65,94,99. All fun to sell but they all have 1/2 price equivelants in other brands. I still have tons of this stuff as well as various Silver Solders and fluxes.
   / Rarer/less-known/different welding rods I have #11
So far of all the equipment I have, I dont have the first missile (yet) so I will just stick with my basic 6010/7018 which is about as many dollars as I want to spend for welding rods. I guess if I was welding as a business, I would need a lot of different rods. Incoloy 600 usually welded any unknown to unknown back in the days before nuclear metal analyzer except of course the aluminum and exotics like Titanium, zirconium, palladium etc.
Remind me sometime to tell the tale about the Palladium tool box I welded for an iron worker once using Titanium rods before he found out the value of it. It stayed hidden under a fab table for at least 2 years that I worked at the Celanese plant in Bayport Texas. Might still be there. It weighed about 20 pounds. Looked up the Palladium metal selling price today under precious metal pricing: $575 per ounce.
   / Rarer/less-known/different welding rods I have #12
Yeah, There are usually basic filler metals that can replace the niche items. I always wach the ladies Plasma Weld Gold Rings at one of the Jostens plants. Palladium is a new one for me. Bet you don't stick weld that.
   / Rarer/less-known/different welding rods I have #13
I'm not sure what they used it for at that big chemical plant but the guy said he found the 4'x8' sheet of 1/8" thick plate in their scrap yard. We were fabricating a bunch of Titanium and Zirconium lines for some highly corrosive acid (no idea of the name but supposed to eat thru schedule 40 stainless in less than 1 minute). The Titanium welding rods (TIG) welded it just fine. Titanium has to be welded with internal and external purge and we fabricated a 1.5" wide trailer (small box contoured to the pipe size and filled with steel wool and SS screen)x as long as practical for each size pipe and used that for the Titanium. You only welded the length of the trailer and then had to stop and hold it in place till everything cooled off. If oxygen gets too it before the weld metal cools below about 500F then it hardens. I think that is how the Titanium coated drill bits are made. If it is contaminated, it turns from silver to straw colored on to a blue depending on the amount of oxygen it gets. We checked the welds for hardness using a needle sharp tungsten. A good weld you could scratch, but even slightly contaminated and you couldnt scratch it at all and brother that is hard when you cant scratch it with a tungsten point. Any thing that wouldnt scratch had to be cut out and redone. We also welded some Zirconium there and no one knew how to weld it and Brown and Root didnt have a welding procedure. There were 3 of us working on how to weld it. All we knew was a bit of info we got from the pipe fab supplier that it had to be welded in a complete inert atmosphere so we built some plexiglass boxes with rubber glove inserts similar to what you see on tv with scientist handling deadly toxins. We had boxes made for butt joints, Tee joints & 90 ells with several glove inserts in different places so you could position yourself to see the weld. Zirconium is very resistant to acid but it oxidizes easily when hot. Both the Titanium and Zirconium can be cut like butter with an oxy torch, if fact when it gets hot, you can literally swing the torch as fast as you can and it will cut. Then we had to grind off slowly at least an 1/8" of metal prior to welding. Grinding either material produced no metal dust as it all vaporized in the air and even a file could make sparks from zirconium. They used zirconium filiments to make old flash bulbs. We had on guy using a water cooled saw to cut a piece of it one time and the cuttings go hot enough to flash off like a magnesium flare. We didnt use that any more. Anyway after much experimentation we found a way to weld it but only in the horizontal position using Helium on the Tig gun and Argon in the box. OF course engineers made every field weld in the vertical position so we had two welds to make rather than one.
   / Rarer/less-known/different welding rods I have #14
The combination of zirconium and Brown and Root sounds like you were working in the nuclear industry. What were you doing?
   / Rarer/less-known/different welding rods I have #15
Actually I mostly worked in the Petro-Chemical division and a little in the Power boiler division early projects with the company. Luckily never involved with the nuke side, I spent 45 years helping to build refineries and chemical plants in Louisiana, Texas and California of which about 14 of those years were work outside the USA. Did a little 2 year stint with a small company called Nepco building electric generation facilities in California, New York and North Carolina and 16 months with CB&I building a LNG liquifaction plant in Peru but most of my time was with B&R later called KBR afer the Halliburton buy out of Dresser Industries who owned MW Kellogg. Halliburton merged B&R and MWK companies and subsequent public offering of KBR as independent company. Halliburton nearly ruined B&R in the process as MWK had about a billion$ worth of asbestos liability claims that bankrupted the then Kellogg Brown & Root but they hung together.
   / Rarer/less-known/different welding rods I have #16
I guess I didnt answer the one question. I started out welding then later after being welding supervisor for about 10 years, I moved into the Quality Manager role. My last project was Construction Manager over a Nigerian Pipe Fabrication facility which was a small part (about $40 million of a $7 billion gas to liquids plant that turned NG into synthetic diesel fuel. When I finished that I retired but was asked to go to Algeria on a temp. assignment for some quality issues. Made 5 months on that 2 month assignment, now retired again.
   / Rarer/less-known/different welding rods I have #17
Just the kind of cool stuff I love to read about. Great Career, I hope you trained a lot of guys.
   / Rarer/less-known/different welding rods I have #18
too my knowledge i have not used those rods.when i purchase expensive rods i like the certanium rods.i have not bought any in years.still have a few left from the last can.
   / Rarer/less-known/different welding rods I have #19
I wish I could remember the number of a certanium rod I once used while building a huge addition on a saw mil. The saw mil weldors had this rod I used to weld extension onto ship augers for the carpenter types, sometimes these extension would be 6-feet long, never had one break!:cool:
   / Rarer/less-known/different welding rods I have #20
How long ago did you work for Nepco? Do you remember any of the Superintendents? How about Slick Rick?
They were actually pretty darn big, but not like KBR, CBI, CE or BW. They started as Bumstead and Woolford in Seattle in the '40's, as a erector of Riley Boilers. They eventually went national, and erected all manner of boilers, steam turbines and flue gas assemblies. Atlantic Gulf was started in the late seventies as the merit shop part of Bumstead. The Board sold it to Zurn, who needed an erector for their boiler division, in about 1983. The Woodinville office changed it's name to Nepco about then.
Nepco moved it's fabrication shop to North Carolina prior to 1989, then closed it.
Nepco was eventually sold by Zurn to Enron, who has subsequently sold it to a Canadian firm. It still has a presence in the Bothell WA. area.
AUCTION STARTS HERE @ 9AM (A60429)
AUCTION STARTS...
Chemical Containers Tank (A57148)
Chemical...
2005 GMC C7500 24FT BOX TRUCK (A59904)
2005 GMC C7500...
2007 MACK GRANITE CV713 DUMP TRUCK (A60430)
2007 MACK GRANITE...
2020 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A59904)
2020 FREIGHTLINER...
2022 Kubota LX2610SUHSD Compact Utility Tractor (A55315)
2022 Kubota...
