lilranch2001
Super Member
- Joined
- Nov 25, 2009
- Messages
- 6,250
- Tractor
- Bobcat CT 235
I am going to go on a limb, and make the statement that 90+% of compressed air lines in American industry is black pipeI have had issues with using black iron threaded pipe years ago but it was in the building codes a long time ago.....the issue I had was the condensation of compressed air was making rust inside the pipe......resulting in rust fragments coming out ruining air tools if they were not filtered and oilers installed
I can't say I've had any PVC or plastic pipe in my shop but I'd wonder if there was a fire wouldn't the pipe melt from the heat and explode?? and fan the flames right where you don't want them??
I use copper (the heavier type-L) anchored properly with drop legs in the entire shop except for a piece of hyd hose (not regular air hose) from air comp to the wall (to reduce vibration) and have always been happy with the results....... and it looks very professional looking for the local authorities and insurance inspections......and the condensation (no rust) doesn't bother the air-tools and blow-guns
I realize using plastics will work but I can't take the gamble if there is even a slight chance of catastrophic failure......I wouldn't want to work for an employer that would cut corners like that so why would I take short-cuts and expose others to those potential hazards
:2cents:
You should not use galvanized, as the zinc tends to flake off, copper is prohibatively expensive, PVC, well I am not needing to comment on that any more.
Back when I was doing pipe fitting for a living, all the compressed air I put in was either cut n threaded or welded sch 40 pipe.
In the last year, I have had two new compressed air systems installed in 2 different buildings and a new trunk line ran, all by different contractors and they all used sch 10 black "sprinkler pipe" with vitaulic fittings. It looks like that is the new standard.
