Gear box oil - Kubota 60" mower
   / Gear box oil - Kubota 60" mower #11
were you going for extended changes or a regular interval of say... 3000m.. a good UOA around here costs a couple bucks less than an oil & filter and air filter change with supertech oil.. etc. Seems vs testing it, just better to change it... but that's just me.
My old dodge has been running supertech oil for the last decade... still running. this up coming oil change I've invested a buck fifty more and went to their high milage oil.. see how that does..
soundguy
Normal oil changes and the walmart oil was poor. Ca low, TBN was like <2, ZDDP (what is that)....No OEM says to use 3K mile oil changes.
Yes, the UOA cost more then s supertech oil and filter but the UOA proved it was not providing the proper adds like many others. You get what you pay for. If you like it, great, I will never guy it again.
   / Gear box oil - Kubota 60" mower #12
care to make a small cash wager on that.. I have the manual to my old dodge here in my lap.. :)
remember.. I don't own -anything- new... my tractors are mostly from the 50's.. and a new truck to me is something from the mid 90's ;)
soundguy
   / Gear box oil - Kubota 60" mower #13
One guy is from Ontario and the other Florida. The Super Chinamart will be ok in Florida...In Ontario, good luck!
Supertech is great for dollar store people...sorry...
   / Gear box oil - Kubota 60" mower #14
Supertech gear oil will be more than fine. Rocks, roots, and rust will be your enemy.
Ignore the salesmen posts.
   / Gear box oil - Kubota 60" mower #15
yep...
   / Gear box oil - Kubota 60" mower #16
   / Gear box oil - Kubota 60" mower #17
Nope! LOL....Dollar store and chinamart are based on price, not quality...Sorry, I will use a real fluid and sleep tight.
   / Gear box oil - Kubota 60" mower #18
Lets see the UOA's?
   / Gear box oil - Kubota 60" mower #19
meets minimum sae specs for that application... same as everybody else.
a premium oil may be 'better' , and will cost more... but the basic oil meets the minimums.
for a small sump like a cutter.. and a guy had no other gear oil needs.. I'd likely chip on a quart of 75w90s but for something i use dalot of.. bulk gear oil from a bulk packager just makes for easier stocking.
I've got mowrrs form the 60's that probably had the same oil in them when they were new. ditto on some steering boxes fileld with 50w engine oil.
any lube is better than no lube. a lube meeting mim=nimum specs will be fine. a lube meeting mor ethan the minimum will be fine and cost more.. and may last longer? on a sump with no filter.. i like to chnge oil out to get rid of debris and metal and moisture.. ths no extended change interval bonus. probably no cold pour point issue either on a mower gearbox. most peole don't mow inthe snow.. :) for something changes 300-600 hrs or ever 2ys.. cheapest gear oil you can buy that meets sae spcs can't be too bad.
ran walymart gear oil in my dodge front and rear rear ends for over a decade. before I sold the dodge a few monts ago I had both open.. for a looksee and a seal in front and gaskets. gears were fine? walmart oil must be bad then right?
no uoa needed. it's a common sense thing.
besides I know this argument you are trying to have with me is a carry-over from another post. I see thru that.. :)
   / Gear box oil - Kubota 60" mower #20
well, using your reg, corn oil would be fine! My issue is you are comparing issues from FL to Canada...Not even close.
Gettomart is just that...If you like it great, no even close on UOA from other fluids....
Post a UOA on your chinamart and that a real fluid????? Please do....LOL...the results will show what is a lesser fluid.
CAT 973 (A47384)
CAT 973 (A47384)
2014 International PayStar 5900i S/A Flatbed Truck (A52377)
2014 International...
2021 Doyle 8 Ton Trailer Tender (A53472)
2021 Doyle 8 Ton...
UNUSED JCT 40' CONTAINER (A51244)
UNUSED JCT 40'...
2009 Trail King TK110HDG-523 RGN 66 Ton Tri-Axle Lowboy Trailer (A52377)
2009 Trail King...
