New Holland E9NNB401AA CUSHION, SEAT new numer will not Holland F1NNB401AA no bolts
   / New Holland E9NNB401AA CUSHION, SEAT new numer will not Holland F1NNB401AA no bolts #1
ohio farmer04
Gold Member
new holland tn
old number 81869847 CUSHION, SEATNew Holland 81869847 CUSHION, SEAT
new holland new replace number will not work no where bolt it F1NNB401AA no bolts
*FD 3210 RB
Cushion Mfg. Part
# F1NNK402AA (3/90+) (Bolt in)
# E9NNK402AA or CA (Clip in )
Backrest Mfg. Part
# F1NNB401AA (3/90+) (Bolt in)
# E9NNB401AA or CA (Clip in)
STANDARD COLOR: Black
MODEL #
250C Utility Tractor*
345C Tractor Loader*
345D Tractor Loader*
445C Tractor Loader*
445D Tractor Loader*
545C Tractor Loader*
545D Tractor Loader*
3230
3430
3930
4130 (3-cyl) Ag
4130 Narrow*
4630
4830
5030*
5640 w & wo/cab*
6640 w & wo/cab*
7740 w & wo/cab*
7840 w & wo/cab*
8240 w & wo/cab*
8340 w & wo/cab*
*denotes more than one seat option per model
AVAILABILITY
Alt Item: N/A
Assembly: N/A
Covers:
Seat: FD 3210C
Back: N/A
Cover Kit w/Foam: N/A
New Steel: N/A
Rebuilt Steel: Your Cores or Ours when available
Seat: *FD 3210 RB
Back: *FD 3210B RB
Full Foam Back: *FD 3210B F RB
Wood:
Seat: FD 3210 WB
Back: FD 3210B WB
E9NNB401AA CUSHION, SEAT with clip well not wotk need one F1NNB401AA (3/90+) (Bolt in)
sorry got numbers wrong
   / New Holland E9NNB401AA CUSHION, SEAT new numer will not Holland F1NNB401AA no bolts #4
I'm looking for bolt-in cushion set for my 1995 Ford NewHolland 445D ......cushion numbers are # F1NNK402AA (3/90+) (Bolt in) and E9NNB401AA...where? can I get them? Thanks Doug
messicks new holland is where i got them
they top one in stock them get botton one hard time finding it wrong slip not bolt they did find it
did you find the seat?
   / New Holland E9NNB401AA CUSHION, SEAT new numer will not Holland F1NNB401AA no bolts #7
Yes, found replacement cushion set at TractorJoe.com Part number was TKBL and fits a long list of tractors including my Ford/NewHolland 445D. My seat was made by a company called "Grammer", apparently supplied lots of tractor companies. https://www.tractorjoe.com/catalogsearch/result/?q=tkbl&machine_type=&brand=&model=&x=18&y=20
The 4 seat cushion holes for the back and the bottom matched perfectly, although the new back didn't have holes for the brackets used to "stow" the seat belts.....the new set bottom DID have the holes for the seat belt. I had to fully disassemble the seat assembly in order to get at the bolts....about a 4 hour learning experience. I'm pleased so far with the affordable new cushions, compared to the Ford/NewHolland outrageous price.
2018 CATERPILLAR 305E2CR EXCAVATOR (A51242)
2018 CATERPILLAR...
2017 DITCH WITCH RT30 RIDE-ON TRENCHER (A51242)
2017 DITCH WITCH...
2019 Energreen EVO 40 Robotic Tracked Flail Mower (A52128)
2019 Energreen EVO...
1984 GROVE AP-308 CRANE (A51222)
1984 GROVE AP-308...
2008 UTILITY REEFER TRAILER (A51222)
2008 UTILITY...
2016 Ford E-350 Enclosed Service Van (A50323)
2016 Ford E-350...
