Seafoam
   / Seafoam #181
   / Seafoam #182
Anyone use this?
Absolutely, it has been a great product for my machines. It has really helped my gasoline lawn tractors to start consistently through the cold months. It stabilizes, preserves your gas or diesel. Use it for the Mahindra as well. I use about 1/3 or 1/4 a can per 5 gallon container. I try to always have it on hand. It may add a bit of smoke to your exhaust.
   / Seafoam #183
i see the point about an easy grab for a back field working on a tractor, needing a charger for a drill or lights or just battery charger etc.
   / Seafoam #184
Skip the seafoam. Use water of Amsoil Power Foam 10X better.
   / Seafoam #185
Dump a dose of Isopropyl alcohol gas line antifreeze for fuel injected equipment in the tank instead. It's the active Ingredient that dissolves gum, goo and varnish while absorbing water.
Draining the water/condensation from the carb bowl would start a lot of engines that magic elixers have "saved".
* * *Draining the water/condensation from the carb bowl would start a lot of engines that magic elixers have "saved".
Do I hear an echo in here?
   / Seafoam #186
Sea Foam is just a 70 year old product to remove piston carbon build up vs removing the head and scraping it clean in outboard engines. It just so happens to work quite well in crankcases, automatic transmissions and fuel system too from our usage experience.
   / Seafoam #187
+1 I have used it for over 20 years in my auto repair business with success. Following the instructions I use it 1/3 tank. 1/3 crankcase, 1/3 thru the intake and let it sit 30 minutes and drive it works like a charm every time even kills a few skitos on the test drive too just another benefit. :laughing:
   / Seafoam #188
i've fogged a few with atf before.. :)
   / Seafoam #189
Yesiree that will do it! :thumbsup: I had the neighbors call the fire dept on me one time when I had smoke pouring out of all doors dont remember what I ran thru that car but it was a hoot. Too bad the county was sent on a false alarm oh well stuff happens. :)
   / Seafoam #190
If most people caught somebody pouring baby oil, Coleman lantern fuel and gasoline antifreeze into an automatic transmission. There would be shouting, threats and either a beating or the cops being called.
2013 CAT 950K WHEEL LOADER (A52472)
2013 CAT 950K...
2023 HarbinGer V3 Plus 8KW S/A Towable Light Tower (A52377)
2023 HarbinGer V3...
40ft Sea Container (A52384)
40ft Sea Container...
UNUSED WOLVERINE PFA-11-3300G HYD PALLET FORKS (A54757)
UNUSED WOLVERINE...
2012 International 4300 Reefer Truck (A55301)
2012 International...
UNUSED RAYTREE REDM32 - 32" HYD MULCHER (A54757)
UNUSED RAYTREE...
