adding oil to the rear end of a kubota
   / adding oil to the rear end of a kubota #1
case245
pa
kubota 7040sud
i have a kubot 7040sud it is low on rear fluid hydro oil what brand other then kubota can i use without voiding the warrenty the kubota brands to expensive for me to run 45 mins to the closes dealer for a quart of hydro oil
   / adding oil to the rear end of a kubota #2
Tractor Supply Center (TSC) carries a Travelers brand that states it meets Kubota specs at around $50 for 5 gal...2 gals were $23.
i need about a quart i only hope its not dry if it is its going to dealer its under warrenty
   / adding oil to the rear end of a kubota #4
IMHO.. on a warranty based machine.. I'd go with oem fluids.. just because.
it's usually not hard to stock some of what a machine needs to eat. I generally like to keep at least 5g of utf fluid on hand.. and 5g of gear oil.. and 3-4 gallons of engine oil on hand at any one time.
i surely would not buy utf oil by the quart. I don't even like buying it by gallon or 2 gallon.. too expensive that way.
soundguy
   / adding oil to the rear end of a kubota #5
Most of this only meets UDT not SUDT
2007 Ford Expedition EL Limited 4x4 SUV (A53424)
2007 Ford...
2012 CHEVROLET SILVERADO SINGLE CAB TRUCK (A51406)
2012 CHEVROLET...
KUBOTA L2501 TRACTOR (A54756)
KUBOTA L2501...
2008 Isuzu NPR-HD Landscape Dump Truck (A53422)
2008 Isuzu NPR-HD...
2005 V.E. ENTERISES 130 BBL STEEL VACUUM TRAILER (A53843)
2005 V.E...
2009 Bruton T/A Enclosed Livestock Trailer (A52377)
2009 Bruton T/A...
