Advice On Plumbing in Compressed Air Line
   / Advice On Plumbing in Compressed Air Line #41
I ran PEX in mine and have been pretty pleased. Felt it was a good compromise. Did a thread with something like Barn Airlines in the title.
I really felt it important to have the large diameter tubing supplying my air, then when I look around at what we do at work, with hose, feeding a pig feeding another hose, feeding another pig, then to a hose feeding a high consumption air tool like a cut off wheel and we run all day like that (aircraft maintenance hanger with multiple sheetmetal guys at work) I think my next round of expansion will be with those terrible Crapsman air hoses that I have that don't roll for nothing. Just a lot more straight forward, staple them up with wiring stuff and maybe feed a fire extinguisher pig or a copper drop leg if I am concerned about water.
Oh, and the pex is holding up real well, and does not appreciably leak, it stays charged all the time.
Good luck however you go.
   / Advice On Plumbing in Compressed Air Line #43
You are correct. All PVC is brittle. The only plastic I'm aware of that is appropriate for compressed gas is HDPE (High Density Polyethylene). It does not get brittle. When it fails, it cracks or tears, not shatters. It's a great product, but I don't think it would be much cheaper than steel.
I was reading earlier today the ABS is also approved. It splits when it fails rather than shatter. Kinda hard to find though. And I'll bet it's $$$
   / Advice On Plumbing in Compressed Air Line #45
Yes, I guess so looking at the date. Probably did it shortly before posting it. I just leave the air on. May regret it if it blows and my Air compressor dies, but as much as we use it I would hate to have to cycle everything each time.
If you have never worked with Pex it is really really great to work with. Little bit steep to get the tools to play, but once you have them, you will wonder why you screwed around with the other stuff so long.
As to the Pex deteriorating in light, I did wrap a pipe wrap insulation tube (black rubber) on the airline outside from the air compressor into the barn to keep it out of the light.
2012 NEW HOLLAND BOOMER 3045 COMPACT TRACTOR WITH 250TL LOADER (TRANSMISSION ISSUES) (A52748)
2012 NEW HOLLAND...
2015 HINO BOX TRUCK (A52472)
2015 HINO BOX...
2022 CASE 580 SUPER N BACKHOE (A51246)
2022 CASE 580...
BESTWAY AG VSK50 LOT NUMBER 103 (A53084)
BESTWAY AG VSK50...
2014 INTERNATIONAL MA025 26FT NON CDL BOX TRUCK (A52576)
2014 INTERNATIONAL...
