Anyone here own a Maschio 3 pt tiller?
   / Anyone here own a Maschio 3 pt tiller? #1
sixdogs
Super Star Member
Ohio
Kubota M7040, Kubota MX5100, Deere 790 TLB, Farmall Super C
I have a six ft Maschio "H" 3 pt chain drive rototiller and can't figure out how to check the level of the gear oil in the side chain unit. The owner's manual makes no mention of how to check it, only that you are supposed to do so. There is an "oil level" indicator on the side of the cover but no mention of how to know the oil is at that level. Any advice appreciated.
   / Anyone here own a Maschio 3 pt tiller? #2
You look there at the "window" on the side. If you can't see oil your supposed to add some till you do.
   / Anyone here own a Maschio 3 pt tiller? #3
All you do is open the level plug and if oil flows out it is up to the level required if the oil level indicator is the same as on my tiller (different make)
I don't see any window. Where would this be or is that model different from mine?
That's the problem...there is no oil level plug. Just a drain plug and a fill plug. No oil level plug.
I know what you are speaking of but this tiller has no oil level plug I can find.
   / Anyone here own a Maschio 3 pt tiller? #6
Dump some in, dont think you can overfill.
   / Anyone here own a Maschio 3 pt tiller? #7
My BEFCO tiller was the same, no level plug on the chain case. I drilled and tapped a small hole in the chain case and made my own level plug.
Well, I know the answer.
I called Maschio this morning and was quite surprised. He said to get a thin stick, (yup, a thin stick) and dip into the fill hole on top to measure the amount of oil in the side gearcase. Typical Italian, which I love. The answer is to get a thin stick or piece of wire and stick into the fill hole to determine how much oil is in the tiller. Wow, so easy.
It's nice to know in this era of talking cars and safety protections against everything, the Italians still figure our head is more than a hat rack. I'm OK with the answer.
   / Anyone here own a Maschio 3 pt tiller? #9
When I had my new tiller delivered in 09 the oil was so clean I wasn't sure if I could determine if it was showing in the window or not. My brother found a small dowel rod for model building and stuck it throught the top fill as you mention. Kind of embarrasing at the time but a good approach none the less.
2005 GMC 3500 SLE (A53314)
2005 GMC 3500 SLE...
Giyi 72" Grapple (A53316)
Giyi 72" Grapple...
207010 (A55853)
207010 (A55853)
JOHN DEERE 4066R (A53084)
JOHN DEERE 4066R...
2019 Ford F-350 4x4 Crew Cab Auto Crane EHC-4 4,000lb 2 Ton Mechanics Crane Service Truck (A53422)
2019 Ford F-350...
