BFET529
Member
- Joined
 - Apr 16, 2012
- Messages
 - 38
- Location
 - Fowlerville, Michigan
- Tractor
 - Kubota L2550, Belarus 250AS, John Deere 6X4 Gator
I have a 6x4 gas John Deere Gator that won't stay charged.  If I charge the battery, it starts and seems fine.  If I charge it to full, and leave it sit, after a few days or a week, the battery will be dead again.  This leads me to believe something on the machine is drawing power from the battery.  It only has the electronic lift for the box, and headlights that turn on and off (both operated by a simple toggle switch).  Now the catch... If I charge it full, it always starts and runs fine, for about a half hour or so (give or take) and then dies... This leads me to believe it is the stator?  What I don't understand is why, if I charge it to a full battery, woud the battery be dead after a week if is never started or run?  Could the stator be drawing if it is in fact bad?  I would like to think it is the stator because it will charge and run fine, and then die, as if the battery is not being charged as the machine is being run??  Anyone have any ideas?  I am hoping this is a quick fix so I can use the machine again!  Sick of getting stranded wherever it decides to die on me!
Also, from my reading on similar problems, a lot of people seem to have a problem with a bad voltage regulator? Does this have anything to do with the type of problem I am having?
Thanks for all the help!
