Have you checked your FEL mounting points lately?
   / Have you checked your FEL mounting points lately? #11
I know I can be a bit rough on my FEL, but aren't we all. So I do have a regular check around and a couple of days ago found the spring washers for the bolts holding on the FEL subframe to the chassis have cracked and dropped out. I pulled a bolt out and it is quite OK but had to go to town to get some 14mm spring washers to replace them all. It would be easy to overlook this as they are a bit hard to see in some places.
That is why I keep all of my loader mounting points and hardware securely rusted to my tractor. Hasn't budged in just about forever...
JayC
2227 (A58376)
2227 (A58376)
40' High Cube Multi-Door Container (A57149)
40' High Cube...
40ft T/A Gooseneck Flatbed Equipment Trailer (A55851)
40ft T/A Gooseneck...
7ft Double Legs Lifting Chain Sling (A57454)
7ft Double Legs...
Metal Sunflower Spinner (A57454)
Metal Sunflower...
2012 JACK COUNTY TANK 130 BBL STEEL (A58214)
2012 JACK COUNTY...
