alternator conversion massy 135
   / alternator conversion massy 135 #1
kayak
newport,TN.
67' MF 135
the generator armature shaft broke,so i'm going to change it over to an alternator,i just happen to have a spare alt. in the garage, i made all the brackets i need,and have it mounted on the tractor. i'm looking for a diagram or just an explanation on how to connect the alt.to the existing voltage regulator,or do i need to get a different regulator. i dont know where the alt.came from or what it fits. its a delco alternator with 2 post batt.,and grnd.,2 -1/4 in. spades marked "R"&"F".
   / alternator conversion massy 135 #2
Try this link. Tyler Woods explains it very well. I read his notes amoung others before doing mine. In my case I eliminated the voltage regulator because the alt had one built in. I also changed out the amp gauge to a volt gauge. I have a thread (link below in my signature) where I'm refurbishing my 135, (4 cyl gas version) mostly cosmetic which shows a few pictures where I modified the dynamo bracket. Take a piece if thick rope to check the length of belt you will need. It will be longer and got mine at autozone for few bucks. I aquired an alternator similar to yours but was equipped with a tachdrive on the rear to keep all my instruments functional.
BTW, if you need a hood and sides for your Perkins, I'll make you a good deal. I bought a new hood and sides and found out later that the Perkins and Continental hoods open on opposite sides. If I had knows this, I would have asked the question about the hood before purchase, so it was part my fault and didn't force the dealer to take it back.
Good luck on your conversion. If you have questions, at some point, we can help you out. -robert alias "the kid" :thumbsup:
Updating The Charging System of Your Older Tractor
2002 MANAC 48'  WALKING FLOOR REFUSE TRAILER (A53426)
2002 MANAC 48'...
MURRAY 22" 2N1 SELF PROPELLED PUSH LAWN MOWER (A51248)
MURRAY 22" 2N1...
ECHO GT-225 GAS WEED EATER (A51248)
ECHO GT-225 GAS...
UNUSED FUTURE FT13J EXCAVATOR (A51247)
UNUSED FUTURE...
2024 KUHN SL124T LOT IDENTIFIER 130 (A53084)
2024 KUHN SL124T...
2016 Case CX160D Hydraulic Excavator (A51691)
2016 Case CX160D...
