STUMPED TC30 gauge shows over heating how to check gauge??????????
   / STUMPED TC30 gauge shows over heating how to check gauge?????????? #1
smokethelineman
Dallas NC
Newholland tc30
OK there is no water in oil, no oil in water, no bubbles in water, temp never goes above 186 by the thermo image gauge, replaced sending unit. Problem still the same within 3-4 min the temp is in the red I was going to take the gauge out. Can I run 1 wire to the battery in 1 wire to the sending unit hook the other ends to the gauge will that work?:confused:
   / STUMPED TC30 gauge shows over heating how to check gauge?????????? #2
You're sending unit is a variable resistor that resistance (ohms) get less as it heat up and max when it is cold. On mine cold is 690 ohms, operating temp is 140 and at 1/8" before red is 66 ohms. You need to find the spec on your sending unit and find the numbers above for you rig. most likely it will be pretty close. You can short out the wire fo the sending unit to the chassis and see your meter pegging out but that does not check for the sending unit. You can read the resistance between the sending unit and ground while cold and at running temp, if the reading is way off of the specs for your sending unit then you need to invest in about $25 to buy a new one. Did not get your wiring and checking scheme but make sure not to put direct battery voltage on it as it will for sure fry it and becomes useless. Your gauge is reading the resistance and not voltage to show you the temp.
JC,
(1) HD 24ft Free Standing Corral Panel (A51573)
(1) HD 24ft Free...
UNUSED JCT 84" PUSH BLADE (A51248)
UNUSED JCT 84"...
ECHO GT-225 GAS WEED EATER (A51248)
ECHO GT-225 GAS...
UNUSED FUTURE JBD 32" MIXING BUCKET (A51248)
UNUSED FUTURE JBD...
Toro Workman MDX Utility Cart (A51694)
Toro Workman MDX...
2020 New Holland 105 Workmaster MFWD Compact Tractor with 632TL Front Loader - Poultry Special (A53472)
2020 New Holland...
