The Little Blue Tractor That Could
   / The Little Blue Tractor That Could #1
RDrancher
North Texas
New Holland
Not all, but most of the threads in the NH section of TBN are posted in regards to problems with our tractors and how to go about getting them fixed and back to work. We're not alone, it's the same for all of the other brand-specific sections too. So I thought...why not share all of the good things about my own blue machine and find out what the rest of you like about yours?
Just like most folks, my Boomer TC35D is used to maintain my property, but it's also used for my business. In fact, my tractor has been responsible for over 90% of my income since I've re-focused on performing jobs I want to do instead of dealing with a bunch of employees or subcontractors, and taking on projects that I know beforehand will be a PITA. I wanted to have more fun working, and in the last 35+ years of being a contractor operating equipment had been the most fun...there just wasn't enough of it. The downturn in the economy and a move halfway across the country made this change possible and I feel truly blessed for it. Since I've made this change its been amazing to witness first-hand just how much work can be accomplished with one guy on a tractor, and sometimes a laborer or two.
My tractor works almost daily performing tasks it was never designed to perform and does it quite well. I still brushog here and there, but in a typical week the little blue tractor can be found installing gravel driveways, cutting grade on smaller jobs, or moving hundreds of yards of dirt for landscape grading. In fact, in the last six months that has included a 1000+ cubic yard select fill landscape job and most recently a large gravel parking lot. The parking lot job involved mixing and installing 900 cubic yards (45 semi loads) of road base over geotextile. This was accomplished in two and a half days, installing 400 cubic yards a day in the first two days and then the last 100 yards of gravel used for dress-up. My material supplier commented that he had been putting it on me pretty heavy and couldn't believe that a 35 hp tractor with a box blade could keep up. I was pretty amazed myself, and it gave me even more appreciation for the tractor and more "ammo" to fire at customers when I don't show up on the job with a skid steer or compact track loader.
Bartonville Gravel 02.jpgBreshirs Grading 15.jpgBrush Hog 01.jpgCelina Grading Loader.jpgDoverspike After05.jpgEquip Roller Tractor.jpgFM 01.jpgJanuary During.jpgNeilson Cattle Guard.jpgTooth Bucket.jpg
All of this work with the tractor hasn't been without some substantial breakage and normal wear and tear. In the last 2200 hrs of use I've broken quite a few 3PT lower sway control arms (inner and outer) and even broke the upper loader pivot at the loader frame completely off. It turned out that the bung weld lacked sufficient penetration. Got it welded up and back working the next day. The radiator split at the seam and was beyond repair so I had to replace it. That breakdown was actually my fault. I was brushogging a place I call "****'s Ten Acres" and the radiator plugged with cottonwood seeds and overheated. I'm much more diligent now in keeping the radiator clean. Once, during a Texas blizzard (all you folks up North can laugh now) I broke off one of the quick attach arms. I guess hitting it with a sledge to get it closed isn't such a good idea. I also had a failure of one of the final drive bearings. Luckily I caught it before it really tore anything up. The loader and bucket pins have been replaced (some twice) and I've done quite a bit of welding and reinforcing on the "Heavy Duty" bucket too. The old bucket is on it's second bolt-on cutting edge so I shouldn't complain. I've gone through an annoying injector pump leak, 3PT bounce and the dreaded no start syndrome...the latter two being repaired with a ton of help here on TBN. The tractor is in the shop now for the diesel leak and I'm none too happy with the shops ability to fix then break it, or for the EPA for requiring tamper proof bolts to get to six little o-rings, that's for sure!
Anyway, I thought I share some of my experiences owning the Little Blue Tractor That Could. It's been fun!
   / The Little Blue Tractor That Could #2
Nice work RD!:thumbsup: My first knee-jerk reaction is say a skid-steer could probably do many of those jobs quicker, but grading with a boxblade and having both the FEL and 3PH to use at the same time makes many jobs much faster. Having a tractor to also run a shredder is a big plus. The skid-steer might be more rugged, but the initial cost and the cost of attachments is also probably far more than that TC35D. Good luck with your continued business. I hope that injector pump gets fixed soon so you can make good use of our cooler August weather. I'm sure I don't have to tell you that having enough rain to keep down dust and the heat is great for tractoring.:)
Thanks Jim. :thumbsup: Your knowledge and advice have been a great help in keeping me up and running over the last year or so!
Having cut my operating teeth on skip loaders (industrial, landscape loaders), the tractor / box blade combo is a natural for me..."tractor neck" and all. I personally despise rubber tired skid-steers, but that probably has more to do with the old hand /foot control models. Nothing seems more unnatural than picking up stuff with my feet. I do rent joystick (pilot) control compact track loaders for the heavier grading work these days. I'm hoping that will help keep this tractor rolling for a long time.
I'll update the injector pump problem in my other thread. I will say that the "reputable" shop has spent more time breaking it than fixing it! :rolleyes:
   / The Little Blue Tractor That Could #4
That's an impressive amount of work & gives a guy like me (new to tractoring) a little more courage to try new things. My little blue is tiny compared to yours, but I'm amazed at how much working is easier with a little blue help! Thanks for sharing. I'm learning a lot.
   / The Little Blue Tractor That Could #5
Be careful, yours may end up into two pieces like mine! Just kidding!
   / The Little Blue Tractor That Could #6
Texas blizzard???
U sleigh me.
   / The Little Blue Tractor That Could #8
The scuts and cuts are the Swiss Army Knives of tractors. My little blue tractor has been a pretty tough machine, and I can't think any other type of equipment that can do so much at what is really a low to reasonable cost. If they do need repair, it isn't cheap, but not nearly as much as other heavier types of equipment. For my purposes, it's gets me by without a yard full of yellow ornaments.
I haven't had any major failures yet in 1370 hours, knock on wood. It's never been back to a dealer. My bell housing has a crack, but it has stayed the same now for almost two years. I am beginning to wonder if I cranked too hard on the chain binder several years ago when I used to trailer it, and just never noticed until the threads about TC's breaking in half came along.
I have two new Ohio lights (the double-sided amber lights on the rear fenders) to install. Bush hogging among low trees is hard on those. Someday I have to do something with the slop in my FEL pins. 2003 TC's did not have bushings in those. I discovered a guy nearby who is a pro welder and has a line boring machine - yahoo. I think it can be rebuilt into something better than factory.
   / The Little Blue Tractor That Could #9
RD-
Probably a really dumb question- bear with me- with a box blade, do you fill it at the "high" spot and keep the load from emptying the box by keeping it level with the grade (neither adding to or emptying the box) until you get to the low spot or raise the box where you want to "dump" the load? Is that how it works?
RD-
Not a dumb question at all. That's pretty much how it works, depending on what you're trying to accomplish. If you use your scarifiers to loosen up the high spots first, you can usually generate quite a bit of dirt to deposit in the low areas. To carry a grade you need to learn to feel what the front end of the tractor is doing in relation to the back. When the front of the tractor goes up the box blade goes down and visa versa, so you have to make adjustments to the 3pt as you go. If you mess up and get dips, back-drag with your fel and start over. Back-dragging can fix a lot of whoops moments while you're getting the hang of it.
ATTENTION PLEASE READ (A57148)
ATTENTION PLEASE...
2130 (A58376)
2130 (A58376)
CATERPILLAR 255 SKID STEER (A52709)
CATERPILLAR 255...
2001 POLARIS RANGER UTV (A58375)
2001 POLARIS...
1998 PETERBILT 379 (A58214)
1998 PETERBILT 379...
2234 (A58376)
2234 (A58376)
