Diesel in oil?
   / Diesel in oil? #1
sierradmax
1998 Bobcat 763 & 2009 S-175
Under routine maintenece on my 763, I noticed the oil level on the dipstick was quite high. In addition, the oil appeared to be very thin. It's either antifreeze or fuel.
I drained the engine and placed in a clear jug. I didn't see any seperation which makes me believe its fuel. Hwoever, is there a definite way to tell? The machine still runs fine but I'm scared to run it any longer as the oil thins out even more. Besides fuel leaking into the cylinder or bad rings, where else can fuel leak into the motor?
   / Diesel in oil? #2
Check the fuel injector pump seal. Neighbor had to rebuild his JD with this issue. Mechanic told him the injector pump seal failed allowing fuel into the crankcase.
   / Diesel in oil? #3
This happened to me several years ago with my JD 820. The mechanical fuel pump diaphragm ruptured, allowing fuel to enter the crankcase. Replaced the fuel pump and problem was solved. I would definitely check this out before you get involved with the injector pump.
   / Diesel in oil? #4
The diaphragm/lift pump would be first palce to check for fuel in oil. If is was anti-freeze it should settle out in your sample jar plus the wohuls be other indications such as loss of coolant, constant bubbles in over flow bottle, and probably some smoke due to blown head gasket or cracked head.
2022 John Deere 5075E MFWD Tractor Loader (A53485)
2022 John Deere...
2017 Ford Explorer AWD SUV (A51694)
2017 Ford Explorer...
John Deere 5065E 2WD Tractor with Canopy (A55314)
John Deere 5065E...
1996 JLG Commander CM2033 20ft Electric Scissor Lift (A55851)
1996 JLG Commander...
2017 DRAGON 130 BARREL TRAILER (A55745)
2017 DRAGON 130...
UNUSED FUTURE 350 HYD BREAKER HAMMER (A52706)
UNUSED FUTURE 350...
