sdkubota
Congratulations!
Congrats Tom. I Look forward to following your progress.Settled on the new 3.5 acre property on Friday.
You might consider resizing you pictures smaller before uploading them. Your first pictures are very large and don't display very well using a mobile device (slowwww to the point of unusable). I typically resize my pictures to 640x480 before uploading them to my thread on TBN. Makes for friendlier viewing. Just a thought.All exterior cleanup is complete. The two trailers are empty and into a 30 yard dumpster. Tree removal underway. Pictures will follow.
That kind of hornet is very agressive. I once wrecked a tractor after I bush hogged a 2 foot tall sapling with a hornets nest on it.I have one tree that has an approx 1' diameter hornet/yellowjacket/wasp nest up about 30'. Any suggestions on how to cut it down and avoid the critters? Cut and run? It is too high up to spray with anything. I have no water source out here.
You might be able to knock the hornets nest down using a shotgut but be prepared to run.
I wouldn't try this method with a nest as big as yours.haha ... in NJ? Maybe that would work in TN, but here, I'd be arrested before the sound reverberation is gone. Townhouse development 1/4 mile away (out the back of the property).
