46GT deck 321190 on 1641 Cub...
   / 46GT deck 321190 on 1641 Cub... #1
Draphty
Hey everyone...I'm having an issue with my cub. I get about 3 hours of cutting time from new, original cub deck belts. It seems the belts stretch and then no longer want to stay on and come off. It seems to me a shorter belt would help my problem. The lever arm where the spring attaches, actually contacts the belt when this problem occurs. When the belts are new, the arm is probably a half inch away. Anyone else have this issue?..I think about a 1 inch shorter belt would solve the problem. Ideas, suggestions? Thanks!
Draphty
   / 46GT deck 321190 on 1641 Cub... #2
Are you using a aftermarket belt or Cub Cadet? The Cub cadet Part# for a GT46" deck is 954-3039. I have a 1864 with a GT46" deck and this is what the part # that I use. I looked up the GT 46" (321-190 mower deck belt) number for a 1641 and 1864 they use the same one.
I'm using the original cub cadet belt.
   / 46GT deck 321190 on 1641 Cub... #4
OP - unless you are cutting some heavy growth, for that belt to stretch that much within 3 running hours indicates something wrong in the belt "train", possibly a failing spindle bearing, sheave, idler pivot, etc. A careful visual inspection while running (be safe) for any vibration/wobble etc. followed by a hand check of all pulleys etc. for wobble/loose play with drive belt disconnected just might uncover a culprit or two... particularly if the tractor/mower have accumulated a fair number of hours...
Hay Van FL-95 Bale Squeezer - Hydraulic Bale Grab for Round and Square Hay Bales (A52748)
Hay Van FL-95 Bale...
2012 FORD F-650 ROUSTABOUT TRUCK(INOPERABLE) (A52472)
2012 FORD F-650...
2020 JOHN DEERE 333G SKID STEER (A51246)
2020 JOHN DEERE...
2015 INTERNATIONAL MA025 (A52472)
2015 INTERNATIONAL...
Bobcat 3400 4x4 Utility Cart (A51691)
Bobcat 3400 4x4...
2022 Club Car Tempo Golf Cart (A51694)
2022 Club Car...
