jejeosborne
I run my engine speed based on the task at hand. Finish mowing it is necessary to run at high rpms to get blade tip speed as quick as possible for a clean cut. My rotary cutter on the other hand will cut at a much lower speed. If the brush is high and thick, I run at pto rated speed. If the brush is thin, I run at much lower speeds to keep dust, vibration, and fuel consumption down. I never lug the engine but full throttle is not necessary. As far as the hammer comparison, I don't drive finish nails with a 10 lb sledge hammer.
