Oil & Fuel GL 3940 front axel oil change
   / GL 3940 front axel oil change #1
jem041279
Abbeville, La
2011 Kubota L3940 4x4 w/ FEL & John Deere 750
I have decided to go with gear oil in my front axel but not sure if I need to spend the extra money on synthetic oil or not. My feeling is regular 80w 90 gear oil would serve my purpose, please give me reasons that I should not go with that, btw I typically do not use 4wd if that makes any difference. Thanks
   / GL 3940 front axel oil change #2
I have a grand L 3130 and I changed my fluid to 80-90w I bought at tractor supply. I think mine took 5 quarts or so. Works for me.
   / GL 3940 front axel oil change #3
I would go with conventional oil, synthetic is like $18 a quart.
   / GL 3940 front axel oil change #4
I drained the HST oil and put regular dino 80w in. Even if you do not use 4wd much the gears still turn when the tractor moves. I'm a bit old school and just feel better about gear oil. Kubota says either will work. Be sure to drive around a bit and check the level again. The oil needs to get evenly distributed between the left and right side of the axle. :thumbsup:
   / GL 3940 front axel oil change #5
Do what the manual says to do.... :reading:
   / GL 3940 front axel oil change #6
I just did my L3540 and put synthetic in mine. Took less than 4 1/2 quarts.
   / GL 3940 front axel oil change #7
The polymer chains in synthetic give longer hang time; in a gear bath system there is not much advantage to that since it is always somewhat submerged.
Syns flow and lubricate better at temp extremes; I can have minus 30F in winter and 110 plus in the summer.
I use Mobil 1 syn gear oil in my L5740 front for those reasons, and I decided to use gear oil (instead of transhydo fluid) because I have a non-scientific thought that it might be better for the pressures involved in geared systems.
I am a tractor waxer, so I also use syn oil (Mobil 1), and syn THF (Chevron All Weather THF).
500 BBL FRAC TANK (A58216)
500 BBL FRAC TANK...
TANK MANIFOLD (A55745)
2025 Nationcraft 8.5X36TTA3 38ft Tri-Axle Enclosed Trailer (A56859)
2025 Nationcraft...
HYDRAULIC THUMB CLAMP FOR MINI EXCAVATOR (A58216)
HYDRAULIC THUMB...
72" General Purpose Skid Steer Bucket (A59076)
72" General...
Steel Storage Cabinet w/Contents, 67" W x 24" D x 96" H (A59076)
Steel Storage...
