fuel and lubricants consumption
   / fuel and lubricants consumption #1
gabps
kumba/ south west region
i will like to own one
1 What quantity of fuel can be used in plowing a hecta of land.
2 What is the cost of hiring a tractor per hr.
3 What is the life span of a tractor.
   / fuel and lubricants consumption #3
1 Depends on the size & condition of the tractor, the type of plow and the nature of the land.
2 Varies from place to place and with the size of the tractor and whether you rent it from an individual or rental place
3 Depends on the tractor, but mostly on how well it's maintained. Abused tractors last a few years. Well maintained tractors last a very long time. There are many 60 to 80 year old tractors in regular use.
If you are considering plowing some land, go talk to neighboring farmers to learn what you need, then make a few calls. And keep reading TBN.
   / fuel and lubricants consumption #4
General design guideline - 3,000 for a sub-compact utility, 5,000 hours for a compact utility, and 10,000 hours for a full size agricultural tractor. Here in the USA the standard rate for moldboard plowing is USD 14.62 per acre in Kansas. Most of the surrounding states - Nebraska, South Dakota, Iowa, Minnesota, recommend the Kansas State Department of Agricultural Economics publication for a general guideline but vary from there based on local conditions (fuel, soil, etc.). I use that for setting my custom harvest rates here in Minnesota. Since you said hectare, however, I assume you are not in Kansas anymore, and any place using hectare for field measure will likely have higher fuel cost. The K-State publication, available for free on line as a PDF file, has lots of historical agricultural work rates. I am especially familiar with custom grain harvesting rates having tested equipment with harvesters throughout the US for years and the numbers match my records.
Leeboy 685 Grader (A47477)
Leeboy 685 Grader...
2017 FORD F-550 XL SERVICE TRUCK (A51406)
2017 FORD F-550 XL...
UNUSED IRANCH HYD EXCAVATOR THUMB CLAMP (A54757)
UNUSED IRANCH HYD...
2018 Taylor-Dunn BigFoot B5-440-36 Electric Utility Cart (A50324)
2018 Taylor-Dunn...
2020 VOLVO VNL64T860 TANDEM AXLE SLEEPER (A54607)
2020 VOLVO...
2018 Nissan Titan 4x4 Crew Cab Pickup Truck (A53422)
2018 Nissan Titan...
