Tree Spade on Front Or Back Of A 6400 John Deere
   / Tree Spade on Front Or Back Of A 6400 John Deere #1
Old Pipe Welder D
Ontario, Canada
6400 JD : : 150 NewHolland skid steer, Case TR-270 Skid steer
Hey guys I'm planing on building another tree spade this time for the John Deere tractor/loader.
I want it to spade a 50" rootball:thumbsup: give or take a few inchs
The tractor that I have is a 85hp JD:D -6400 and I beleive the back end weighs more than the front end.
This makes me wonder where to mount the spade on the front loader? or on the 3ph.
Any thoughts on this are apreiciated.
Thanks
Old Pipe.
   / Tree Spade on Front Or Back Of A 6400 John Deere #2
From the university of Tennessee, home of the World Famous Middle Tennessee Nursery Association. As 50" rootball should weigh about 2,000-2,600 pounds. Of course as the disclaimer states; "Weight will vary with soil moisture, soil type, type of plants, etc."
Add the weight of the tree spade to the weight of the rootball/tree and you will have you answer.
The answers to questions I would want to know are:
Can the JD front end loader handle the job on a continuous basis?"
And can the 3-point hitch lift the rootball high enough to get the rootball out of the ground without damaging it?
Caliper Ball Diameter Weight of tree and Rootball Weight of tree and Rootball
(In inches) (In inches) (In pounds) (In tons)
1-2 22 260
2-2.5 24 340
2-3 28 560
3-3.5 32 880
3-4 38 1100 0.55
4-4.5 42 1500 0.75
4-5 48 2000 1
5-5.5 54 2600 1.3
5-6 60 3100 1.55
6-7 68 3800 1.9
Trunk Diameter Ball Diameter Ball Depth Weight of tree and Rootball Weight of tree and Rootball
(In inches) (In inches) (In inches) (In pounds) (In tons)
5 50 29 1.6
www.utextension.utk.edu/mtnpi/handouts/Field Production/Rootball_Weights.pdf
1-2 22 260
2-2.5 24 340
2-3 28 560
3-3.5 32 880
3-4 38 1100 0.55
4-4.5 42 1500 0.75
4-5 48 2000 1
5-5.5 54 2600 1.3
5-6 60 3100 1.55
6-7 68 3800 1.9
5 50 29 1.6
Thanks for that Information and chart, It will be usefull.
I think now I will be building a 38" to 42" spade....and run it from the loader
Cheers
ST205/75R15 Trailer Tires (A55787)
ST205/75R15...
2018 John Deere 245G LC Excavator - Hydraulic Thumb, Tooth Bucket, 56K LB Class (A55302)
2018 John Deere...
378721 (A54865)
378721 (A54865)
2022 NEW HOLLAND 266BMM 66-INCH BELLY MOUNT FINISHING MOWER WITH SIDE DISCHARGE (A55301)
2022 NEW HOLLAND...
KIVEL TRAILER MOVER ATTACHMENT (A55787)
KIVEL TRAILER...
