Correct fluid level on NH 1920 e4x4 front axle housing?
   / Correct fluid level on NH 1920 e4x4 front axle housing? #1
2dawoodz
Is the correct fluid level for the front drive housing just above the etched end of the dipstick? If the current fluid level is 1 inch above this mark should I drain or OK as is? Thanks!
   / Correct fluid level on NH 1920 e4x4 front axle housing? #2
Fill level is anywhere on the hashed portion of the dipstick. If yours is overfull, drain it to the proper level. Overfilling a non-vented axle such as yours will lead to pressure fluctuations greater than normal due to the decreased volume of air trapped in the housing and eventual seal failure. ideally, if the oil hasn't been changed in a while, you should drain a pint at a time from the final drive housings as this is typically where the dirtiest oil is found.
2014 VOLVO VNL DAYCAB (A58214)
2014 VOLVO VNL...
LEINBACH 1R CULTIVATOR (A52708)
LEINBACH 1R...
IMPORTANT PLEASE READ!!!! TERMS AND CONDITIONS (A57453)
IMPORTANT PLEASE...
2015 DRAGON  130BBL VACUUM TRAILER (A58214)
2015 DRAGON...
2017 Ford F-550 4x4 Cab and Chassis Truck (A56858)
2017 Ford F-550...
JOHN DEERE TRACK TRACTOR (A54756)
JOHN DEERE TRACK...
