Spraying UNDERSIDE of vegetable plant leaves
   / Spraying UNDERSIDE of vegetable plant leaves #1
JDgreen227
Super Member
Central Michigan
4210 MFWD Ehydro--'89 JD 318
Every vegetable plant pesticide I have used such as Sevin, as well as a multitude of online sites, advise us to be sure, quote: "to spray the UNDERSIDES of leaves...".
HOW does one accomplish that? I have never found a tank sprayer that has a nozzle except straight, if one had a nozzle that could be adjusted to a "U" shape that would help with some plants, but my pumpkin plant vines cover a 35 foot square area and even if I had such a nozzle I couldn't possibly get close enough to spray the undersides of leaves except on the outer edges, because I would have to trample on the vines.
Does anyone here have a method to spray leaf undersides? I tried bending a brass sprayer nozzle one time to a curved shape and all that did was destroy the nozzle.
   / Spraying UNDERSIDE of vegetable plant leaves #2
copper tubing may be an answer if the OD's match up. Are Organic methods viable for you so spraying may not be needed?
   / Spraying UNDERSIDE of vegetable plant leaves #3
I grow water melons, and was quite frustrated by the inability to get a through coat of fungicide, on the leaves. I finally realized that I needed a powerful sprayer to accomplish this. No pump sprayer will easily get this done with developed plants.
I have a 6 GPM gas powered tank sprayer. Using a 90+ psi stream, and a gun like a pressure washer, from 20 feet away all the leaves flip up when you spray them. It's almost funny to watch. Makes short work of jobs like this, that would otherwise be difficult.
Don't expect similar results with an electric sprayer, to do this is going to require spending money, or getting a good deal on a used one.
I would not mind a PTO driven unit, even bigger than I have. It would make spraying the lawn faster.
Thanks for the query...would much prefer to go organic so pesticides not required but here (Mid-Michigan) I doubt it will ever be possible. And ray66v...what a solution you suggested...now I am going to try using a handheld electric blower to see if it flips the leaves...what a solution you have found !!!
   / Spraying UNDERSIDE of vegetable plant leaves #5
I must say, that is a brilliant idea. :applause:
Let us know how it works for you.
JOHN DEERE 5115M TRACTOR (A51243)
JOHN DEERE 5115M...
2001 AMADAS 2100 LOT NUMBER 251 (A53084)
2001 AMADAS 2100...
2019 FREIGHTLINER M2106 DEBRIS BUCKET TRUCK (A51406)
2019 FREIGHTLINER...
2021 Exmark Lazer Z 60in Zero Turn Commercial Mower (A52377)
2021 Exmark Lazer...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A54313)
2019 INTERNATIONAL...
2008 JCB 520-40 TELESCOPIC FORKLIFT (A51406)
2008 JCB 520-40...
