Adding weight to an underweight Box Blade (Woods BSE4 Heritage)
   / Adding weight to an underweight Box Blade (Woods BSE4 Heritage) #11
Good question. Ill measure it next time its hooked up.
I dont know the exact measurement, but I noticed no difference in max height after adding the weight
Thanks, I'd appreciate it, actually if you could just measure the lift arm pins to to the ground unhooked that would be good enough. I have a king kutter xb box blade and want to get something better. I know with a bx you have watch what you buy because they do not lift real high.
With the BB installed.
C/L of pins ~24" off the ground
Rear of BB 12"
Hope that helps:thumbsup:
   / Adding weight to an underweight Box Blade (Woods BSE4 Heritage) #13
Rear of BB 12"
Thanks, that does help. If see one on craigslist I'll get it if the price is right. I was worried that the bx may not pick it up high enough like my rake. If you go over uneven terrain it will barely drag.
   / Adding weight to an underweight Box Blade (Woods BSE4 Heritage) #14
Suggest you try experimenting on changing the angle of the rake without the cement blocks on the blade. In the longer term that might be a better solution.
All the angle changes in the world make no difference when the ground is hard as concrete.:) BTDT sometimes you need brute force ie: added weight to penetrate.
   / Adding weight to an underweight Box Blade (Woods BSE4 Heritage) #16
Nice work. I also recently added a section of railroad rail to the inside of my BB...what an amazing difference!
Yes, I know, old thread.
Having said that, how about pics of your install? Thanks!
   / Adding weight to an underweight Box Blade (Woods BSE4 Heritage) #17
I just saw this thread, Scooby. Nice work. Recently I used my new BB to level a neighbor's back yard for a patio. He watered it down the night before. The rippers and blade worked pretty good in the dirt/gravel mix It is a 54 inch 335 lbs BB. The next day he wanted to go deeper for the base. Now it was getting tough. So I had this 225 lb guy ride on the back edge while holding on to the middle support. That really made a differance in cutting an even depth without the rippers down. Total 560 lbs made the differance. I hope he is around the next time the BB is on.:D
2012 DODGE RAM 5500 FLATBED (A58214)
2012 DODGE RAM...
Dump Truck Body with Tarp System (A55851)
Dump Truck Body...
2015 Volvo VNL 64T (A55315)
2015 Volvo VNL 64T...
2019 Ford F-350 4x4 9FT Flatbed Truck (A56858)
2019 Ford F-350...
Landoll Lowboy Trailer (A56435)
Landoll Lowboy...
UNUSED 89" LAND PLANE (A52706)
UNUSED 89" LAND...
