John Deere Transmission Fluid change
   / John Deere Transmission Fluid change #1
bubbacuse77
Wisconsin
John Deere 3520, John Deere X749
Anybody do a transmission/hydraulic fluid change on their 3000 series tractors, specifically a 3520. JD dealer is asking $75 for a transmission sump filter. Also anybody use other less expensive hydraulic fluid besides the brand name JD stuff and have you had adverse affects.
   / John Deere Transmission Fluid change #2
Deere's list on this filter is almost $100, sounds like you are getting a little bit of a deal here. Unfortunately hyd/transmission filters are the most expensive filters for any of these applications (regardless of tractor color). Am assuming you are beyond the warranty point or would not be considering a brand change of oil, if still under warranty tread carefully would be unfortunate to not have a drastic failure pd for just to save a few bucks on oil.
   / John Deere Transmission Fluid change #3
I quit running JD oil after I read about using other make equivalents....(the hours drive one way to the dealer helped as well) Tractor now has 4500hrs on it. I have a local source for filters as well but I don't recall the price.
Guys, thanks for the inputs
   / John Deere Transmission Fluid change #5
I even use JD Hy-Gard in my Kubota and MFs.
   / John Deere Transmission Fluid change #6
I will add to the comments.
You have an expensive piece of equipment so why go cheap on lubricant and filters.
I always use the John Deere oils and filters.
Have to do a hydraulic oil change with 2 pails of oil at $136 each in Canada. Ouch
2014 DRAGON 500 BBL FRAC TANK (A53843)
2014 DRAGON 500...
Ford Super Duty FX4 Pickup Truck Bed (A51691)
Ford Super Duty...
2021 NEW HOLLAND TS6.130 TRACTOR (A51406)
2021 NEW HOLLAND...
2014 MultiQuip WhisperWatt 40kW Three-Phase Diesel Generator (A52377)
2014 MultiQuip...
2015 PETERBILT 365 (A52472)
2015 PETERBILT 365...
MISC PIPE WRENCHES (A53843)
MISC PIPE WRENCHES...
