JD 300 Series BUCKETS
   / JD 300 Series BUCKETS #1
pane056
Lake City, Michigan
CaseIH 685 & JD 3320
Hello;
Is there a way to determine the differance between a Standard 300cx Bucket and a Heavy Duty 300cx Bucket?
I don't find any Data plates or tags on them.
thanks, nicholas
   / JD 300 Series BUCKETS #2
Cutting edge. Hd is bolt on I believe.
   / JD 300 Series BUCKETS #3
Hello;
thanks, nicholas
I believe you will have a double thickness of steel welded to both sides of the bucket. Also the top will be boxed in to re-enforce same. The bottom will have a second cutting edge (and I think it's bolted on). Basically, the whole circumference of the bucket is double thick to prevent bending.
I got a lightweight bucket with my tractor....and added plates to the sides and the top....then added a tooth bar to get a HD model.
   / JD 300 Series BUCKETS #4
The JD heavy duty bucket is boxed in with a second piece of steel along the top. The front edge of the sides of the bucket are reinforced. There are 4 straps welded across the bottom of the bucket instead of 2. The hd bucket's welded on cutting edge is pre-drilled for a bolt on cutting edge. That cutting edge and bolts cost extra. Hope this helps.
Bobcat 72" Skidloader Bucket Broom (A50775)
Bobcat 72"...
Towable Diesel Generator (A55851)
Towable Diesel...
2018 Ford Fusion Hybird Sedan (A55758)
2018 Ford Fusion...
2014 Chevrolet Impala Limited (A55853)
2014 Chevrolet...
2019 CATERPILLAR D6K2 LGP CRAWLER DOZER (A52706)
2019 CATERPILLAR...
(2) GAS HEATERS (A54757)
(2) GAS HEATERS...
