Suspension Seat....PLEASE, anyone have this or used one?
   / Suspension Seat....PLEASE, anyone have this or used one? #1
kyles974
Florida/Alabama area
John Deere 2320 with 200cx FEL...RM550 Woods Finish Mower...GradeMaster Grader....Ratchet Rake
Sorry for another suspension seat question. I've searched "suspension seat" in the "title only" but I still get 2,000 threads. Spent countless time reading about other seat, but couldn't find anyone using a seat like this.
I have disc problems, etc., etc., and can't take it any longer.
Have a John Deere 2320 with a Woods RFM. I put tennis balls under seat, it helped, but not even close to help my bad back.
Can't afford to spend $300 on a Michigan suspension seat right now, so I was looking at maybe one of these at Tractor Supply.
Universal Tractor Seat with Adjustable Suspension, Yellow - 0278213 | Tractor Supply Company
I see there is good reviews there, but wanted to see if anyone here has had first hand experience with one?
Don't mind doing a little fab work to install and don't mind if it looks a little funny on my tractor, as long as it keeps me from crying :weepy: when I'm done mowing the couple of acres I own.
   / Suspension Seat....PLEASE, anyone have this or used one? #2
M having some internet problems right now so could not look at the link but another sugestion would be a complete grammer seat assy w/ suspension. Should be able to get from about any Ag dealer and should only run about $120 for the whole shebang. For all I know that is what the tsc version is as well.
I searched "grammer seat" and yes, that's what Im referring too. I guess looking for someone that has one or used one, says there suspension is good and doesnt bottom out on a 280lb man, lol
   / Suspension Seat....PLEASE, anyone have this or used one? #4
the only problem with that seat that I can see is the height once installed, it is probably going to be too tall once installed!
   / Suspension Seat....PLEASE, anyone have this or used one? #5
Might be pushing your luck a tad for the standard grammer suspension. But I believe they have since added a unit that can handle the extra weight that we have put to our belt line over the years (I want to say A&I is pushing a big boy version). But yes the grammer seat assy's are pretty good suspension and seat assemblies. You will find a grammer seat assy on many, many open station utility tractors by multiple tractor mfg's. So long as it doesn't put you too high up for machine controls, safety, etc I would go for it. There is also a version that has an angle adjustable base (again you may already be looking at that) and it can be easier to mount in different applications. Some also have a springloaded flip up seat for outdoor storage and should be two choices in seat backs. Trapezoid style and wrap around style as well as about any color you desire.
   / Suspension Seat....PLEASE, anyone have this or used one? #6
I replaced the factory seat on my Yanmar with one of those. It was 1000% better than what was on it. It would still bottom out with my 245 # on it when hitting holes. The spring was tightened as much as I could tighten it. It worked fine for normal rough terrain, but when I would hit those semi-hidden ditches where the water lines was trenched in, I would feel the bottom of it. It does hold you in the seat good though. If you want premium comfort, I am afraid that you will only get that in the $300-400 range.
   / Suspension Seat....PLEASE, anyone have this or used one? #7
I will check into that, I did kinda forget that could be an issue, thanks for the reminder.
ok, thanks
ya, I do understand....about the premium comfort.
your feedback was pretty much what I was looking for. I wouldn't expect a $100 seat with suspension to completely not bottom out.....just wanted to make sure it wasn't like adding a spring that mad you hit the bottom a little harder...if that makes any sence, lol
I guess I need to make a trip back to TSC. cause when I was just there, I just glanced at the seat.....(had other mission on mind)...but they had one out, so maybe I could do an true measurement to see how it would mount and most of all, take it for a ride in the isle....bounce on that sucker, lol
I just didn't want to throw out a $100 for nothing. (tight year)
   / Suspension Seat....PLEASE, anyone have this or used one? #9
One of the reviews in TSC webiste mentioned no seat switch or configured for seat belt. Just a couple things to think about and check out will looking at it in the store.
I read that too, thanks for the heads up. (ya'll are great people here, thanks)
I'll post maybe by next week after I drive out to TSC and see if it's going to work for my JD 2320 for future reference.
2018 Ford Fusion Hybird Sedan (A53424)
2018 Ford Fusion...
28013 (A50322)
28013 (A50322)
King Kutter TG72 Rotary Tiller Tractor Attachment (A54811)
King Kutter TG72...
2016 J&M 1122-20T X-Tended Grain Cart (A50657)
2016 J&M 1122-20T...
2014 INTERNATIONAL MA025 (A53843)
2014 INTERNATIONAL...
